Question about Bernina Activa 140
Long stitch!! i have an urgent job to fix and I tripped on my cord resulting in my sewing machine falling onto the floor. I took it in to get fixed as it was sewing long stitches long.It went well again for a day but then out of nowhere started to sew in long stitch formation in all stitches.Can any body please help me?.
  • Anonymous Mar 22, 2014
    While sewing every third stitch is longer than the previous two
    New Friend:
My stitch length selector knob is not working. The knob turns freely and returns to 0-1 when let go of it. Only sewing the tiniest stitches. Now it also only sewing in reverse. Should I take the back off and see if a part is loose, or oil the selector part inside the machine. Broken or gummed up?
Posted on Sep 07, 2015
  • 202 Answers
If your feeddogs look like they are working properly it could be this...I have seen and corrected a few problems like this in the past. What can happen is your needlebar is stuck in the Basting position. Basting is when even though the machine is turning properly the needlebar will only go down every few revolutions. There is a small pin in the needlebar that disengages when Basting stitch is selected (by an electro-magnet). Usually these will stick from hardly ever or not using it. Old oil gummed up usually but can happen in a drop. The pin will not go back in. Possibly (probably also) the needle bar got turned ever so slightly knocking the hole for the pin slightly off so it can't go back in. In which case the needlebar has to be turned to the correct alignment. This should only be fixed by a trained tech. Everyone... use the basting feature occasionally. We have a saying about those. "Use it or lose it".
Posted on Aug 27, 2007
    Novelist:
    Scholar:
  • 84 Answers
Hi teza...I assume that you have decreased your stitch length selector resulting in no change, indicating that the internal stitch length mechanism is either insufficiently lubricated, or truly broken If not broken, you can work the mechanism free by removing your needle, selecting the maximum stitch length and any non-overlock stich pattern, ie. straight or zigzag, fully depress your foot pedal so it runs at maximum speed, and methodically press and release the Reverse button/lever. After a minute of this, hand crank your machine while observing the feed dogs, and changing your stitch length. If your stich length is set to 0, your should observe your feed dogs moving vertically up and down with no back/forward motion, however, increasing as you lengthen your stitch length. Repeat the previous high speed work out until you notice full strokes of your feed dog...good luck my friend
Posted on Aug 02, 2007
While sawing the embroidery holder moves as well, looks like its not falling into its place correctly after embroidery, how can I fix it? Also I've self checked the machine but cant get the zi
YOUR MACHINE USES A PULSE MOTOR (SMALL MOTOR) THAT CAUSES THE NEEDLE ARM TO MOVE. IF THE MOTOR IS A PROBLEM THEN YOUR ZIGZAG STITCH AMONG OTHER STITCHES WON'T WORK. YOUR HOOP I'M NOT SURE BUT IT SOUNDS LIKE YOUR HOLDER ISN'T LOCKING WHEN YOU PUSH THE HOOPS ON. LOOK INSIDE THE HOLE WHERE YOU PUSH THE HOOP AND TOUCH ON EACH SIDE AND PLACE PRESSURE TO SEE IF THEY BOUNCE BACK. ANYWAY, YOU WILL PROBABLY NEED TO GO TO YOUR LOCAL REPAIR SHOP ON BOTH OF THESE PROBLEMS.
Nov 17, 2014 | Janome Sewing Machines
How do I fix the speed of stitching? When I press on the foot feed I get almost no speed from it.
unless it has been progressively getting slower, I did have a simular issue. My pedal was getting "stuck" at the 1/2 mark. (wasn't pressing all the way down). Drove me nuts. Took the machine apart, cleaned oiled, cleaned again blah blah blah...when the pedal was the last option took it apart and found a nut from a screw had gotten inside the pedal and stopping it from pressed down. There could be a burr, a nick or something it is catching on.
Sep 22, 2014 | Janome Memory Craft 4000 Sewing Machine
The machine seems to work fine when I am sewing two pieces of fabric together. The problem is when I was making double welt cording for an upholstery project. I was adding the second piece of cording and...
first you need to change the Needle to a heavy duty needle that may help a lot. You may want to check ur stitch settings as well. Sometimes work with a heavyweight fabrics or bulky items can throw ur tension and stitches off. So my just need to re adjust them. Manually sew(turn the non) the item first to get the machine going. Then slowly press ur petal.
Oct 19, 2013 | Juki HZL-25Z
My New Home HF-1012 buttonhole stitches don't work.
Take it back... and have him fix it again... this time ask him to tell you exactly what he did to get it to work.
Aug 29, 2012 | New Home HF-1012 Mechanical Sewing Machine
Im trying to sew letters on thin fabric and lace. I think the grip is to ruff for the fabric. how do i fix this?
you will need to have stabiliser behind the fabric to give it stability for any type of machine embroidery.
Look for a product called "stitch and tear" or "solvy" which washes away in water after you've completed the stitching.
Also, consider using machine embroidery thread for this task, its silky and gives a lovely sheen.
I've always used an embroidery hoop to hold the layers all together for monogramming so things don't slip.
I'd suggest you google "machine embroidery" or try www.sewing.about.com and see if there are other machine embroidery tips there.
Apr 05, 2011 | Sewing Machines
Sears Kenmore Model # 5186 Problem with stitch length
I had same problem. Took the dial off and turned by hand.
Aug 05, 2008 | Sewing Machines
Need shop manual for sewing machine
Visit us at www.janomestuff.com to avail for a new manual for only $10.00
Jul 02, 2008 | Sewing Machines
Sewing Machines Logo
443 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
