Question about Remington Precision Deluxe PG-200 Beard Trimmer
Remington pg200 groomer disassembly
Won't charge. Is there a battery that needs to be replaced? I so, how is this groomer disassembled?
    Problem Solver:
This is a very simple repair.
To disassemble, twist the round bottom part (with the battery contacts) counterclockwise just a bit. Use jaw pliers if it won't twist with your hands alone. To protect the plastic finish of the groomer use some duct tape or a rag on the jaws. Gently twist and open the assembly. When separating the bottom part, take care not to pull it apart too far from the main assembly to avoid damaging the 2 thin wires connecting the bottom plate on the inside of the bottom charger to the main body of the groomer. The batteries will just slide out easily; they are not soldered or attached in any way. You can replace the batteries with any two standard AAA rechargeable NiMH batteries (1.2 volt).
Since the batteries are so easy to access, and there is no solder involved, in a pinch you can even use regular AAA Alkaline batteries! (but, of course, NEVER USE THE CHARGER WITH NON-RECHARGEABLE BATTERIES!!)
The groomer is now as good as new!
Posted on Dec 19, 2014
SOURCE: Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Posted on Dec 28, 2008
SOURCE: how do i disassemble remington r-450s
there are three screws, not two. You have to remove the trimmer assembly to get to the third screw.
Posted on May 11, 2010
brector3
  • 1610 Answers
SOURCE: my remington titanium r-950
You will find the correct type replacement batteries at shaveroutlet.com. See link below. You will need to order two
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Posted on Nov 04, 2010
brector3
  • 1610 Answers
SOURCE: I need replacement batteries for a Remington MB
You will find the correct battery type at shaveroutlet.com. See link below
Posted on Nov 22, 2010
Testimonial: "Just what the doctor ordered....Thanks"
woodchuck789
  • 4070 Answers
SOURCE: The rechargeable battery on my
E Bay is a good place to find razor parts. They have new parts and you don't have to bid on them since they have a Buy It Now price.
Posted on Dec 09, 2010
How do i replace batery on a remington 9190
You will find the correct battery at shaveroutlet.com at the link below
http://shaveroutlet.com/norelco-philips-liion-battery-cell-for-select-models-p-564.html
The shaveroutlet video below will help you for disassembly
https://www.youtube.com/watch?v=rGD84BfKxAE
Feb 16, 2015 | Remington Health & Beauty
How to disassemble a remington 700 bolt ?
You'll need a tool similar to this one, James:
http://www.brownells.com/gunsmith-tools-supplies/rifle-tools/bolt-tools/dissassembly-tools/remington-bolt-disassembly-tool-prod7650.aspx
Aug 10, 2014 | DNZ Products DNZ Dednutz Remington 700...
Can't reassemble Remington model 31 shotgun
Dear George,
GO to this link. FirearmBlueprints net Firearm Blueprints Construction Guides More . Should you want to subscribe for a minimal fee.
Dictionary explanation Remington Model 31
Here you go sir. A you tube made for you. Remington Model 31 disassembly by D Tom
Stray offers his approach in this video for your comparison.
Remington 31 disassembly
Fare. Well.
Dec 02, 2011 | Remington Sports Remington 12 Ga...
Remington Electric Shaver..How do I disassemble a Model XLR 900. 8BF2-1C. I want to replace the battery.
Unfortunately these rechargeable razors are not designed to be easily serviced by the home user.
Changing the battery will definitely involve a bit of searching for the multiple screws which hold the case together and then disassembling the case to access the battery compartment. Just watch out for any screws which may be hiding under the rubber padding pieces. You will then likely be required to desolder the old battery out and then resolder your new battery back into place.
Here is a link to a site which describes the various methods for disassembling battery powered shavers:
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Here is a link to a replacement battery available for your model:
http://www.batteryweb.com/cordlessrazordetail.cfm?ID=238
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
May 14, 2011 | Health & Beauty
Has never charged, even after extended time periods - both with car charger and usb. Any tricks I'm missing. I've tried "ejecting" it but it just goes back to showing computer connection....
Sounds like the internal battery won't hold a charge and needs to be replaced. If you're "handy" you could do this yourself, but it's not for the faint of heart, and replacement batteries are available on the Internet. Here's a video that shows the procedure for disassembling and reassembling it to install the replacement: http://www.youtube.com/watch?v=PwAbKYOgiZg
May 11, 2011 | Garmin nuvi 255W GPS Receiver
Te battery will not hold a charge.
Batteries in your shaver model were not designed for replacement. Disassembling the shaver will result in damage to the case as it is glued together.
shaveroutlet.com has a simple and inexpensive solution of replacing the 'lower unit'. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Oct 08, 2010 | Remington Titanium MicroScreen MS3-2700...
My Remington is charged but doesn't work.
Most likely, the heads are either damaged or are too clogged up to spin. First, try disassembling the blades and cleaning them out thoroughly. If this is not the problem, you may need to change the heads. Remington suggests changing the heads every 12 months. You will find these for model R-650s at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-sp29-titanium-rotary-replacement-heads-p-383.html
Jul 07, 2010 | Remington R-650s Electric Shaver
Replacing the battery
Download the user manual - it has battery removal instructions ----
http://safemanuals.com/user-guide-instructions-owner-manual/REMINGTON/MS3-1000
Nov 28, 2007 | Remington MicroScreen 3-3000 Electric...
Remington Precision Deluxe PG-200 Beard Trimmer Logo
1,141 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
