Question about Microsoft Windows Server Standard 2003 for PC
NTL.DR ERROR , COMPUTER IS LOCKED UP
WONT BOOT UP
  • 54 Answers
Do you have a cd, floppy, or usb connected?
Grab a Win 2k3 CD and follow method 3:
http://support.microsoft.com/kb/816793
If it's a virtual machine and you have it backed up. it might be quicker just to restore it.
Posted on Jan 04, 2013
Kenmore stove the oven wont come on it says dr
The DR error can mean that the door lock is enabled (or the oven believes it is). If the oven door was open and the Clean button was pressed, this can happen. Try pressing Cancel with the door closed. If the door is open, press the oven light button in and press Cancel. Try unplugging the oven (or flipping the circuit breaker to off) for a few minutes to reset the error.
If these don't help and the oven is not locked, then the control unit probably needs to be replaced. If you add a comment with the model of the oven, I may be able to direct you to the parts.
If your oven is still under warranty, contact Kenmore. I hope this helps.
Jul 03, 2014 | Kenmore Ovens
How do you get rid of the Canon DR-7550C -4630 error "The device could not be locked"?
It's usually a software conflict.
If you have multiple scanning programs, the one of them may have it locked. Especially if you have a scanning program that runs as a service.
Jun 13, 2014 | Canon imageFORMULA DR-7550C - Document...
Htc first won't boot
Try holding volume Up and volume down together then the power button----hold all three until vibration starts.......that should get you to a factory reset.
Dec 04, 2013 | HTC First Android Smartphone AT&T Locked
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
Hi got the following error message ... "ScanFile
I have many years repairing canon scanners so here is my suggestion to you.
First does the scanner power up? If so that's eliminates a internal power supply problem.
Second did anyone change the dip-switch settings on the back of the scanner? Ill assume no on that one.
Third when you first boot up your computer do you see a screen when the computer is in boot up mode that says Adaptec SCSI and then a number? If not here is a couple things to check. First I would check the SCSI cable is good. No bent pins in the connector and no exposed wires coming out of the connector. If you can try swapping a good known working cable with the problem scanner. Second try re seating the SCSI card if that doesn't work do you have another card that you know works that you can swap into the problem computer. After swapping the cable first test to see if the scanner scans, then if you replace the card again retest to see if the scanner scans.
Lastly and I have seen this happen, the drivers may get corrupted if new software is installed that relates to scanning. You may want to google DR 3020 drivers that should pull up Canon's web site and reinstall the drivers. Once you install the latest drivers then reboot the computer and test it to see if it now scans.
Im sure one of my suggestions should correct your problem. I hope this helps you out.
Mar 18, 2011 | Canon DR 3020 Path-Through Scanner
Dr error code
“do” or “dr” - door problem. The door is not locking, the control is not able to confirm the door is locked. Might just be corrosion on the door lock connection. Or a bad door lock OR an item in the door keeping the door from locking. Manual and more here
Aug 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front load stackable gets a code dr. model#fwtbb30ds0
Hi.
Error DR is door latch error.
Check the door lock, and ensure that it it closing and opening properly.
Disconnect power cord or trip circuit breaker for one minute to reset the error code.
If the error code comes back, then the door lock may be faulty.
The door lock may be tested removing it from the washer and reading Ohms on the terminals to ensure that it is opening and closing the circuit. An alternative way to test the lock is by jumping it, if error comes back with door latch jumped, then fault is on wiring or controller board.
Here all parts and diagrams for this appliance.
Regards.
Ginko.
May 19, 2010 | Washing Machines
At boot I got message ntl loader unable to load
it means your o/s cannot boot up, may be a crash or re-installation required.ntl is a boot ini. file.
Jul 11, 2009 | ASUS P5B-VM SE SKT775 G965 MATX...
Frigidaire Affinity - Code DR - Washer wont start
Dear G.Arnold,
ngfam at you service
When you get an error its best to call service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Microsoft Windows Server Standard 2003 for PC Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
