Question about GE PSF26NGN Side by Side Refrigerator
How to replace temperature sensors In GE Profile Artica PSF26NGN
  • GE Master
  • 16,043 Answers
What is the problem that you are having with it?
Posted on Dec 08, 2012
  • 531 Answers
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
aasc
  • 1606 Answers
SOURCE: GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Posted on Jul 19, 2009
aasc
  • 1606 Answers
SOURCE: I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Posted on Aug 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
  • 736 Answers
SOURCE: no water through door - PSS25MGMA WW
if it still makes ice then that eliminates a lot of things .. if thats the case and you can hear the solonoid operate (click) when you try to get water then you might have a clogged or smashed hose from the solonoid up to the dispenser ... if you cant hear the solonoid operate then check the microswitch that is actuated by the dispenser lever .. also check its wires ... they sometimes break right as they come out of the lower hinge .. .. if the ice maker also doesnt work then check the saddle valve where the hose connects to the main water line ..
Posted on Nov 21, 2009
I need a wiring diagram for my GE refrigerator G5H25JFTACC
The wiring for a GSH25JFTACC should be the same as a Artica Profile found HERE Also HERE is a link to GE Artica/Profile Technical Information, I will be here should you have questions, Thanks Sea Breeze
Mar 04, 2013 | GE Refrigerators
Ge gss25wgmd fresh food freezing
You will need to perform a refrigerator self diagnostic test found in the service manual found here=> GSS25WGMD Service Manual
Then go to page 48 of the service manual (Damper Door Not Opening or Not Closing) GE ARTICA PROFILE TECHNICAL INFORMATION This test will help you determine if the problem is the damper, temperature sensor or the control board. Doing these test are not for everyone and may require that you have someone that can perform diagnostics. If you have questions please let me know, Thanks Sea Breeze
Nov 29, 2012 | GE GSH22JFR Side by Side Refrigerator
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My freezer (ge artica) temperature goes up to 40%, then cools dow
The main problem with the Artica/Profile is that they have a main control board and a thermostat board inside the fresh food compartment. I have a repair manual and will send you a copy if you want but we are going to have to look at the control boards for burn marks. Let me know if you need me. Thanks, Sea Breeze
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
GE PSF26NGN Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
