Question about Garden
My 044 stihl saw does not want to idle - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Does it idle too low then stall?
Up the Idle a bit
Posted on Dec 11, 2012
dontbother10
  • 2220 Answers
SOURCE: no oil is coming out of my 044 stihl saw-I ve
Stihl Product Instruction Manuals page 33
http://www.stihlusa.com/information/info_product2.html
You might also try
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Posted on Nov 17, 2009
Testimonial: "Excellent feed back -step by step repair advice"
lindsay836
  • 677 Answers
SOURCE: i have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Posted on Feb 08, 2010
  • 221 Answers
SOURCE: I am look for a free download for a stihl 044
Here ya go. Let me know if you can't get it. I hope this helps you out.
http://www.stihlusa.com/stihl_ownersmanuals/044_Manual.pdf
Posted on Jun 17, 2010
dontbother10
  • 2220 Answers
SOURCE: How to set up your
A link to an OM for your saw follows:
Page 39 discusses carburetor adjustment.
These are just recommended starting points, the saw should be adjusted for performance. CW is leaner; to lean will ruin your saw.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jan 07, 2011
barterjoe
  • 344 Answers
SOURCE: 044 stihl sawchain wont idle just dies out and
This sounds like an air leak. Checking all of your hoses and making sure the crankshaft seals are good is where to go after adjusting the carburetor to factory settings.
remove the muffler and make sure the engine does not look like this:
barterjoe_9.jpg Consult a gold certified Stihl dealer like www.arcolawn.com for parts and tools to repair all of your Stihl equipment.
Good luck
Posted on Feb 21, 2011
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
Stihl 046 floods
the needle in the card may not be closing all the way
Feb 09, 2014 | Stihl Chain Saw Handle Models 044 046...
My chain wont tighten on my stihl 044 chainsaw
Assuming you have the right length chain and its not just running out of adjustment, it would then probably be a stripped or snapped chain adjuster. Can be coursed when the bar nuts aren't dun up before starting to cut, the force of the chain saw will snap an adjuster no problems. If its striped it might smear like its adjusting in but when it gets to a point it will just stop
Nov 20, 2013 | Stihl 440 044 460 046 Chainsaw Clutch Drum
Where is the bar oil adjustment screw for a stihl ms460
turn the saw upside down, there is a flat head screw adjuster that is accessible from underneath (the bar side of the saw) it will have a + and - sign near it.
Jan 11, 2013 | Stihl Chain Saw Handle Models 044 046...
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
How do you start a STIHL MS460 chainsaw
I am a Stihl mechanic. The proper starting procedure is to set the switch to full choke. Pull the starter rope no more than three times.Now raise the switch up one notch and pull it till it starts. Stihl products will flood if pulled more than three times with the choke on. Thanks, George
May 08, 2012 | Stihl Chain Saw Handle Models 044 046...
I have a stihl 044, older saw and its not running properly. When I try to start it with the full chock, I get fuel ranning out of the muffler every time I try to start it. I take off the air filter and...
I would say it is flooding, you realy need to pressure test the carb to check the seating of the inlet needle, a simple bulb tester is all you need, connect it to the fuel inlet on the carb ( where the fuel hose is connected ), pump approx 2/3 psi into the carb, it should hold this steady with no leak, any leaks then you will have to fit a new inlet needle, let us know how the test goes.
Apr 05, 2011 | Stihl Chain Saw Handle Models 044 046...
Iginition coil test for sthil 044
If it makes a blue spark, it's probably good. More orange, probably too weak.
Mar 08, 2011 | Stihl Chain Saw Handle Models 044 046...
How to set up your carburetta adjustments properly on a stihl 044
Lou
Jan 07, 2011 | Garden
044 stihl sawchain wont idle just dies out and sometimes runs at high idle
Good luck
Dec 15, 2010 | Husqvarna Chain Saw 20" Bar
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
