I have a universal remote. The power comes on, but I can't get it to work. It used to work until I spilled water on it. I know... Red flag. :) buuut I cleaned it up fast and like I said power still co
  • Televison & ... Master
  • 5,418 Answers
Since your remote is responding, you may want to check if it is producing an IR signal. To do this, take a picture of the remote when someone else presses a button. (Have the other person point the remote at the camera lens. With a digital camera (cell phone or other camera), if the remote is producing an IR signal, the resulting picture will show a flare of light.) Taking pictures of several different button presses may indicate which functions are compromised. You can try resetting the codes for the different devices the remote controls.
Unfortunately, you may need to replace your remote with a new one. I've never had much luck cleaning the contacts after they were damaged.
In the future, if you spill water on the remote, first remove the batteries. Then dry the bulk of the water off of the unit. To finish drying the water from the contacts inside, fill a bowl or other container large enough to hold the remote with some uncooked rice. Place your remote (with the battery compartment open) into the rice and leave it there; then cover the bowl. You can rotate the remote in the rice at intervals but leave it in the rice for several days. (The drying process can take a week.) Do not replace the batteries until the remote is completely dry.
Alternatively, get one of the cell phone drying bags and use that to dry the remote. It will still take several days to get all of the moisture out of the unit.
I hope this helps.
(If you aren't in a hurry, sometimes letting the wet gadget dry in the open air for several weeks will work. Trying to rush the drying process doesn't work as well.)
Posted on Dec 08, 2012
I have a jvc 32inch tv and the on and off power button is missing i cant turn my tv wont turn on or off i bought a universal remote and my tv is still not coming on
Program the universal remote following the instructions manual for that model TV. Usually holding the power and TV button until the TV power light comes on. Or, try the combination codes for that model TV.
Nov 25, 2014 | Televison & Video
Reset the remot control for AVOL tv
If you have a an Avol AET3220FD and the remote control ARC-U1 (this is the universal remote that comes with the tv) stops working follow the following steps.
1) Hold tv button until it goes solid red
2) type 523
3) press set button
4) then click power button to check and see if the remote will work.
Feb 03, 2013 | Televison & Video
Need remote code for Apex AD-1201 DVD player w/Comcast universal remote (red OK button, black Comcast letters)
I don't have the original control remote for Apex Ad-1201 DVD player. I would like to use my Universal Remotes: Radio-shack USA "flag" 4-IN-ONE Remote and / or RCA 312W three component remote. I got the codes from the manuals but my DVD player doesn't work or turn off (only ejecting; open and close) with pause button. Could I get a possible code (s) for these Universal Remotes?
Dec 30, 2010 | Apex Digital AD1201 DVD Player
I have a universal remote i dont know the code to my tv can you help me
if it is an rca universal remote you can use the code search, turn the tv on , press and hold code search until the red light blinks, press tv then press power untill the tv cuts off press enter, that should work
Jul 10, 2009 | Philips Magnavox 27MS343S 27" TV
I lost my book
Step1, press the code search button until the led light stays on, then release button, Step2 press what equuipment you want to control, (tv, vcr, dvd, audio) then release. Step3, If you know what codes were used, press the code numbers in and the led will blink 2 or 3 times to comfirm it accepted the code. if you do not know the codes, do Step 1 and Step2, then Press the power button continuosly until the equipment you want to control comes on.
Hopefully this will work for you. This is the way my RCA Universal Remote works.
Good Luck,
Skyassoc
Jun 17, 2009 | RCA 4-Device Universal Remote
Hello I have a philips universal remote, don't know what model it is I thought all Universal remotes was one Model. Last night I tried using it for my TV to swich from TV to DVD and it just stopped...
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Dec 01, 2008 | Philips Magnavox Learning Universal Remote
Dvd code
Try preforming an automatic code search:
1) Make sure the device is on.
2) Hold down the DVD button and the power button simultaneously until the red light stays on solid.
3) Then press the power button - it will flash one time - keep pressing slowly, letting it flash until the device turns off.
4) As soon as the device turns off, press the stop button
If your the remote does not power the device off after cycling through all the codes - You will know this when the power button blinks and deluminates - then your "universal" remote will not work with the DVD player.
The best of luck to you!
Sep 18, 2008 | Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Programing universal remote
Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
Jan 20, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
