Question about Sharp BDHP20U Blu-Ray Player
Disc tray will not close - Sharp BDHP20U Blu-Ray Player
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Someone is going to have to open the unit to see if something is jammed, out of position, or there is a problem with the tray and door.
That simple--you must look to see what is happening.
Posted on Dec 08, 2012
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
My console wont read any of my discs
Typically its a problem with the disc tray, a variety of solutions can be gently tapping on the top of the xbox immediately after the disc tray closes. Another suggestion is, and don't do this very often, but when the disc tray closes, immediately turn your xbox 90 degrees backwards so the Disc tray is facing up at the ceiling. If these fail, you may simply just have to play with the disc tray, grab it while closing, dont tug too much, slam it closed really fast. Microsoft really is **** when it comes to making things last, but these should work somewhat, you might just have to buy a new xbox if they don't ever work.
Feb 09, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Tray closed, but keeps saying tray open
You are having tray sticking problems, you can solve this temporarily by keeping a disc in the tray at all times, even when the console is off or you can give the console a gentle pat close to the front part where the disc tray is, not advisable though because the 360 already has SMD dry joint problems, do this occasionally, try and remove dust also around the grooves under the disc tray, hope this helps
Oct 25, 2010 | Microsoft Xbox 360 Console
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
THINGS TO TRY loadTOCNode(1, 'whattotry'); 1. If possible, remove any discs that are in the tray. 2. Push the eject button to close the tray. 3. If the tray won't close and seems to be stuck, gently move the tray up, down, and to the side. 4. Check around the disc tray and make sure the faceplate is fitted correctly. If the faceplate isn't fitted correctly, the disc tray may not be able to close. 5. If the tray still does not close, contact Xbox Customer Service.
Jul 30, 2008 | Microsoft Xbox 360 Console
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
PS2 auto shut down when disc tray is close
big mistake. never use ps1 cables on a ps2. i made the same mistake once.
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Sharp BDHP20U Blu-Ray Player Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
