Question about Sony RDR-GX300 DVD Recorder
My dvd remote control wont work on dvd recorder but work on tv
I even replace with new battery on it and still it wont work with the unit.
    Top Expert:
  • Sony Master
  • 14,553 Answers
I presume it has buttons to change its operating mode from TV to DVD first?
Posted on Dec 08, 2012
  • 279 Answers
SOURCE: CANNOT PROGRAM
Do you have a universal remote? Sometimes they will forget their programming, especially when batteries are removed, or get low. If you have the codes and instructions for your remote, I would try reprogramming it. If that doesn't work, take it back to the company that did the cleaning. It worked when you sent it to them, or at least if it didn't this wasn't wrong with it. Seems to me they hold some liability in this, and should make it right without charging you.
Posted on Aug 30, 2007
welcomejee
  • 10594 Answers
SOURCE: Remote control for Sony DVD recorder RDR GX3
I just replied your question about remote.
Please click HERE to see.
Posted on Jan 30, 2009
Lanijo58
  • 73 Answers
SOURCE: My remote control to RDR
If you accidentally change your dvd command mode setting to say 1, or 2, and the default is 3, You can only get the remoter to work by turning on the dvd recorder and if you had it on dvd1, as it will display when pushing any button on the remote, hold your enter button and the number your setting is on. this will solve the issue and you can access your dvd player again. If the command mode is on dvd 2, you hold down the enter button and the #2 down. It took me a while, but it will work.
LJ
Posted on Jun 07, 2009
SOURCE: Problems with Sony RDR-GX300 DVD Recorder....I
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Posted on Mar 28, 2010
  • 9 Answers
SOURCE: Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Posted on Jul 22, 2010
How do I order a new hitachi tv remote unit
I popped mine apart and cleaned the negative battery connection. Works like new
Feb 11, 2015 | Hitachi Televison & Video
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
My remote wont work it says set 1
You can try this simple idea; to re-code the remote to your unit, press and hold 1 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore the remote command to match the unit, and thus the remote should work. Failing that, replace the batteries in the remote with new ones, and repeat the above suggested procedure.
If the remote is triggering 'SET 1' on the unit's display, this simply means the remote code is different to the unit, and hence the remote requires a reset to restore control to it whenever the batteries are replaced. Easy enough to fix, doesn't take very long, and should not cost anything except some new batteries if required.
Apr 28, 2011 | Panasonic DMRES15 DVD Recorder
Samsung DVD r135 no reaction using remote control but recorder reacts on remote control from Samsung TV, batteries check. Disconnect the recorder from the power over night no change, still own remote...
Try this. Remove the batteries from the recorder's remote control and hold down the POWER button on it for 30 seconds. Then replace the batteries with fresh ones. It should work fine after that.
If not, the remote control may be defective.
You can purchase a new remote control at www.samsungparts.com
Mar 01, 2009 | Samsung DVD-R135
Remote Control Code problem
I read through other problems on the web page and tried them
Finally I got one of them to work
Thanks
Feb 28, 2009 | JVC DR-DX5 DVD/HDD Recorder
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Remote Control not working
Heh, I got exactly the same problem 3 days ago. Question is, is it the remote or the unit itself?
Dec 30, 2007 | Samsung DVD-HR720 DVD Recorder
Remote control will not work?
Hi Quad, recently I also got same recorder and faced the same problem with the remote controller. today i tried to solve this. i opened it up. it turned out the battery connections are not proper. The battery connection are in the form of a spring coil which touches the outerside of the battery which is not touching properly. I bent and slight lift it with a plier and it started working. The other connection is touching front side of the battery(on backside you see label cr2025 printed) and this is alright. I hope it works for you too. with best regards
Nov 26, 2006 | Cyberhome DVR 1600 DVD Recorder
Sony RDR-GX300 DVD Recorder Logo
52 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
