Samsung LCD TV LA32R71BD Standby High pitched noise
My samsung LA32R71BD is making a high pitched sound from the power supply area of the TV when the TV is in standby mode. I've done some googling on this and have found the problem to be the power supply choke coil needs replacing. I have very little electronics experience and can solder very basic things only. Which choke coil would I need to buy to replace the faulty one? The serial number of the board on the back of the TV is BN64-00445F. Is it an easy job to do for someone with little experience? Is there any danger if I just forget about it and continue using the TV anyway? Will it have a flow on effect and fry the rest of the TV if it doesn't get fixed?
  • John Smith Dec 08, 2012
    The high pitched sound is only in standby mode, it goes away if the cord is pulled out of the wall or if the tv is turned on.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Its going to be a choke (coil) or a small transformer. It can be pinpointed in many cases with in your case set off and back off---use a plastic probe and press on individual coils and transformers (Google will if you search with Photo of..........) show you what they look for, if you narrow it to one part hot glue on a transformer where the wire is or super glue on a coil wires where wrapped can cure this.
No danger to my experience but can be very annoying---Women seem to be better at hearing that sound than men.
Of course if you Google the model number with PARTS you will come up with one of several venders who list all boards by model number and sell them---Power supply is often listed as SMPS.
Posted on Dec 08, 2012
Testimonial: "ok thx I'll give it a go"
5 Suggested Answers
  • 280 Answers
SOURCE: Samsung LCD from standby to on, and off again.. keeps repeating.
The cap's will look puffed. there are usually several on the power supply that are bad. Yes they have to be soldered in and they have polarity so you have to get them in right.
Posted on Oct 23, 2009
Testimonial: "clearly very knowledgeable. FYI, I found a thread on the Samsung forum on CNet. This appears to be a very common problem, Samsung offered to fix 50 NC"
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 68 Answers
SOURCE: The TV doesn't power on.
The problem might be on your power supply section.
1. Check for open resistor or maybe a shorted transistor. Use a multimeter
2. Also check for a leak capacitor
Is the fuse you replace is still o.k? at times the blown fuse indicates that there is a short circuit on your t.v. Maybe the noise you hear is also because of a short circuit. Be careful in replacing fuse, always replace same type for the protection of you t.v
Hope this may help you
Posted on Aug 20, 2011
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
When turned on the screen is blank and makes a high pitch buzz
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
High pitch noise when on or off
Some ferrite cores of power supply regulator might poise this problem. Check for it.
Jul 07, 2012 | Samsung P2370HD 23 in. TV
I have a Samsung 3D TV (46C7000).I have developed an intermittent sound fault. When the TV is switched on I get a high pitched Tone emitting from the TV over the sound of the broadcat program. Sound is...
The tv have a problems in it power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.Power supply board have some bad high voltages transformers.That why ur tv even getting a high pitched sound even the tv it is off and tv it is not even on,and tv it is on standby mode only.
Sep 22, 2011 | Samsung Televison & Video
Hd tv makes a hjgh pitched sound whats wrong
Hi, the high pitched sound is coming from the coils or transformers on the power supply.
you can isolate the noise by removing the back and with the set on press gently with a plastic handle/item on each coil till you stop the noise. , you will probably have to replace the coil or the whole power supply, but sometimes you can tilt it over or secure it with silicone and it will stop rimging.
please click a thumbs up it this helps solve your problem
Eric
Aug 19, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Electro Med Services...
