Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 37MF437B/37 keeps blowing fuses - Philips Magnavox 50ML8105D 50" HDTV DLP TV
    Top Expert:
  • Philips Master
  • 14,553 Answers
Either a short somewhere---which fuse? The one at the power cord or what?
Other possible reason is wrong fuse----many of the fuses in these sets are special-----if you go and buy some Generic ones--hardware store or Radio Shack the fuse even with same amperage/voltage rating may blow at turn on instantly for no reason------
Posted on Dec 08, 2012
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: I need help in identifying whether or not my
Google the model number--owner's manuals are available on the internet for free.
This model (37MF437B/37) IS A 1080P SET.
If you need more information or advice let me know--I am here to help people.
If this helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 07, 2009
What causes#37 fuse to keep blowing on 2004 chrysler pacifica
The fuse goes to the auto shutdown relay from there it goes to two powertrain control modules. Test the relay or replace or there is a short in the system
Oct 04, 2014 | 2004 Chrysler Pacifica
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
Is there a common power issue with Magnavox Model 42MF337B
u have the main switching power supply unit blown. fuse will immediately blow as u have mentioned. they all use smps (switched mode power supply system).  it may be concealed under aluminium plates or cover. look for a  transformer with yellow insulation tape covering near the ac mains input. it is a high frequency tranformer with solid ferrite core. near it there should be the main switching section with a heat sink attached.
Apr 13, 2010 | Televison & Video
I need help in identifying whether or not my magnovox is 720p or 1020p. The ID # is 37mf437b/37 and the serial # is bz3a0722610855
SD TECH
Nov 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv keeps going off
check the ac output socket if its working, power supply is not working
check the following
switch contacts fuse, semi conductors transistors,diodes, zener diodes, fuse resistors,
this will make your tv to oscillate
Apr 11, 2009 | Philips Magnavox 42MF521D/37 Television
Fuses no. 7 & 37 on my 318is K-reg Bmw keep MELTING.
you have to figure out where there is a short in your wiring--follow wires, look for broken, missing insulation--if it started in lights, look there first maybe. Also check the connections of plugs. Good luck it may take some searching.
Mar 27, 2009 | 1996 BMW 318
Keeps blowing fuses
When a fuse keeps blowing, that is an indication that some component has failed and the circuit is drawing too much current. Most likely it is a problem in the power supply section or high voltage / flyback section.
Sorry to say, you will need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
