Question about Uniden Qt206 Thru Hull, Digital Depth Gauge
Will the through hull transducer on the qt-206 work with any other similar depth finders
  • Uniden Master
  • 693 Answers
The Airmar P79 transducer will work with many instruments.
Check out the cross-reference link below.
-Steve
http://www.airmartechnology.com/marine-product-search.asp?q=P79
Posted on Mar 16, 2015
3 Suggested Answers
hydetech
  • 113 Answers
SOURCE: Replacement of an old Impulse QT206
I believe it is the same model. Even if it is different, it will probably work if it has the same type of plug.
Posted on Jul 24, 2008
aloha27
  • 693 Answers
SOURCE: I was told that the
Hi!
The transducer for your depth gauge will not work through an aluminum hull. A drilled through-hull transducer or a transom mount transducer are your options here.
Just in case you require it, your Owners Manual can be viewed/downloaded at:
http://ca.binnacle.com/pdf/Uniden-QT206-manual.pdf
Hope this helps..
Posted on Jun 21, 2011
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
Best way to clean depth finder transducer
There are many websites that can tell you how to clean your transducer.
Check the link below.
-Steve
clean depth transducer Google Search
Aug 25, 2012 | Uniden Qt206 Thru Hull, Digital Depth...
I was told that the Uniden QT-206HP depth sounder will not work thru an alunium hull is this true or false
Hi!
Hope this helps..
Jun 20, 2011 | Uniden Qt206hp Digital Depth Gauge With...
Whta fluid do I put in a QT-206 transducer base when mounting it inside a fibergalss hull ? I had heard baby oil ...
You can use mineral oil, baby oil, I recommend the environmental friendly (pink) antifreeze.
May 18, 2010 | Boating
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
My furuno depth finder gives me crazy depth readings after i go over 10knots..whats the problem?
Turbulence on the transducer is almost certain. If transom mounted, **** it slightly deeper aft and ensure that the leading edge is not exposed. If through hull, call me 847-746-0100
Nov 03, 2009 | Furuno 1850WF Gps Fish Finder Combo...
Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
Jul 07, 2009 | Boating
Unit showing 88.8 in the LCD window.
Hello geld1. Your problem is the transducer, cable or connector. Check transducer with an ohm meter, flex the cable while ohming the restance shouldn't change. The location and mounting of the transducer could be the main problem. Use the the correct gel film including a secure postion support.
Sep 22, 2008 | Uniden Qt206 Thru Hull, Digital Depth...
Jul 14, 2008 | Uniden Qt206 Thru Hull, Digital Depth...
Uniden Qt206 Thru Hull, Digital Depth Gauge Logo
287 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Greg Cann
Greg Cann
ray gallant
Are you an Uniden Boating Expert? Answer questions, earn points and help others
