Question about Durabrand CD2160 Shelf System
Putting the Radio Back Together
I was trying to take the DURABRAND CD2160 Mini Audio apart to fix the CD changer, but i to apart to much and now i need a free maunal to put it back together again
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: wiring guide for durabrand 1210 cd changer
you can find the diagram at www.installer.com
Posted on May 23, 2009
SOURCE: Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Posted on Nov 25, 2009
My cd won't read n how can I fix the problem n need know how to put the cd plastic back together too
Possible that the laser is damaged or needing cleaned. Try buying a laser cleaning cd run that and see if that helps. Good luck
Jan 28, 2013 | Car Audio & Video
Cd wont play it picks up an goes around but wont play need to know what to do
It sounds that the optical pickup unit to your player is faulty. Open the top cover of the player, power it ON and insert a CD in to. Check whether the inserted CD loads well into the mechanism and spins. If do not spins, sled motor is faulty. If it spins, optical pickup unit should be replaced.
Apr 23, 2012 | Durabrand CD2160 Shelf System
Where can I obtain a CD2160 stereo system, either new or used in good condition?
I see you don't read your emails, or you would know that I didn't have a problem with a Durabrand CD2160, but I want to obtain one since they aren't manufactured anymore.
Nov 06, 2009 | Venturer CD-2160 Shelf System
Wiring guide for durabrand 1210 cd changer
May 23, 2009 | Durabrand DB1200 CD Player
Cd stuck, press eject, little sound, does not eject, 2004 Dakota
try taking this apart and removing your disc, then once put back together it should stop malfunctioning :)
hope this helps
Feb 16, 2009 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
CD Player does not eject CD
Just took one apart tonight. Same problem, put in cd-played fine-push eject then click click click.
2004 nissan sentra 140 watt single cd player/radio.
This dash comes apart by pulling the top of dash (with the tray) straight out the clips should release. the bottom part had to be pried a little, then remove four screws and slide out the radio still attached to the mount and dash etc. One screw holds on the top of the stereo. After removing the screw you must pry the top off. Now it gets a little tricky, you must remove the cd player portion, however there are 5 tiny springs holding it down to some pads. The two springs in the rear are under a piece of the stereos frame held on by two screws, I had to use various sizes of tweezers to get the springs off. Lift the player out of the radio about an inch, you will see one 1/2" ribbon in a connector, the top of the connector slides out along the ribbon to release. The other ribbon about the same size plugs into a small daughter board in the radio, it just pulls out and pushes in (you can feel it is reinforced). once out turn it over and you will see what would be considered a gearbox, (small white gears in a see through case) one of the corners of this case has a screw through it. This corner has broken away from the board letting the gears come apart when trying to eject (this is the clicking). I took a soldering iron and melted the plastic back together and put a small amount of 5-min epoxy on for good measure. When putting back into case you can hook up the ribbon cables before all the spring grief and test it out. Mine worked perfectly again. Be care full when putting back together, there are a lot of little micro switches that must be in the correct position) Example, if the cd is ejected the white arm on the right side must be in the correct position. the read head (laser) must be away from the center of the cd. I believe it was easier to put together with it in the cd-in position (without a cd in it) so the laser must be toward the center of the cd. Don't force the laser, use the worm gear to move it in or out. I couldn't put one of the springs back on but it still works fine Good luck, it's not as hard as it sounds
Jul 30, 2008 | 2003 Nissan Sentra
CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
May 13, 2008 | Sony CDX-T69 6-Disc CD Changer
Cd stuck
All You Have To Do Is Unscrew The Radio And Take It Apart. Take The CD Out And Put It Back Together Again. This Solution Worked Like a Charm For My Stereo.
Mar 15, 2008 | Jeep AM/FM Cassette with CD Changer...
Durabrand CD2160 Shelf System Logo
16 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
