Question about Maytag HAV2460AW Top Load Washer
Maytag washer model hav2460aww made a clicking sound then stoped working does not drrain spin or agitate is there a reset button
  • rfrancis969
    rfrancis969 Dec 08, 2012
    Thanks Everone for the help. I unpuged my washer for about 20 minutes, then pluged it back in and it worked.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
No there is not. Check the lid switch for continuity. Here is the part to order in case you find it bad.
Posted on Dec 08, 2012
  • 1294 Answers
SOURCE: Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Posted on Jun 05, 2007
watugot
  • 290 Answers
SOURCE: Maytag MAV6200AWW does not spin
Be sure to check inside basket very carefully to make sure no loose nails or screws or drill bits etc that were left in a pocket are sticking through a hole in the basket and locking it to tub. This is common. If that is not the problem,one of three things has happened. 1 The thrust bearing that releases the brake has worn out. This is the most common and easiest thing to repair. If you tilt the machine back so you can look under it you will see the pulley that turns the transmission. When the pulley turns one direction it works the agitator, turn it the other direction and you should see it push the brake up that is directly above it. The thrust bearing kit includes the pulley and all bearings and washers to release brake. If you are mechanichal and can follow the directions that come with it, it is a fairly simple repair. 2 The brake lining has come apart and "stacked" itself in the brake housing. Replacing the brake is not hard, but there is about 200lbs of spring force pushing against the brake and housing that must be released slowly. I would recommend you call a technician for this just because I don't want anyone to get hurt trying to follow my directions on this repair. 3 An item of clothing has found its way between the basket and tub and has the basket bound up. This would mean removing agitator and basket. It is not likely this has happened, but I have seen it before.
Posted on Oct 04, 2007
Master_Tech
  • 770 Answers
SOURCE: maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Posted on Jan 27, 2008
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
Frigidair flexcare top load washer. Is there a reset button or somthing els i could try ro get it to agitate and spin again?
Most common cause, if all else works Fill , Pump out ) is a loose or faulty door switch or one of its connections .
Apr 17, 2016 | Washing Machines
Maytag HAV2460AWW struggling to spin and drain
Gently tilt machine backwards and look underneath for stretched or damaged drive belt.The drive belt also runs pump. If it is slipping under load then the machine will not spin at full speed and pump out the wtare correctly, thuis leaving some in the machine at the end of the cycle.
Sep 07, 2012 | Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Washer agitates while filling and runs water when it should be spin cycle
filling and agitating at same time could be pressure sw / but if filling in spin / I would replace water valve . sounds like its stuck open . . when washer stopes does the water stop. ?? if not may be timer .. your is hard to diag . need to know brand and model # ,, mm
Dec 08, 2009 | Washing Machines
Agitator on maytag sav2555aww won't spin, loud clicking noise
I just replaced the trans in my maytag.if the washer is less than 5 years old trans is covered under warranty. but here is the kicker, labor and thrush bearing is not. trans cost is about 300.00 and labor is about the same. a new washer is about 450.00 So if you know someone who can do trans.[like for free] if not buy a new one. Good Luck
May 21, 2009 | Maytag SAV2655A Top Load Washer
I have a clicking sound on my maytag neptune washer. it clicks through the whole cycle, is that normal? it sounds like clicking and then spinning, like wheel of fortune show
I would check the agitator,( the middle part of the washer that turns back and forth, hence agitator) and see if it is snug, by popping off the cap at the top of the agitator with a flat-head screw driver, and then checking to see if the nut is on tight or the four little hooks, that hook onto the jagged teeth, around the top of the agitator. I hope that this helps.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag HAV2460AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
