Question about Craftsman NEXTEC 11812 12 Volt Lithium-Ion 3/8-Inch Reversible Drill/Driver
Removing chuck trying to replace warped chuck with a factory replacement, i removed all 5 surround bolts including the one next to trigger but to no avail.
3 Suggested Answers
  • 97 Answers
SOURCE: I need to replace the chuck on my 19.2v drill
You may need to use a impact screwdriver.
Posted on Mar 19, 2009
  • 518 Answers
SOURCE: How do you remove the chuck of 18 volt cordless drill?
lock an allen key in chuck,,chuck has l/h thread so turn chuck anticlockwise to remove
Posted on Jul 07, 2010
Tool piece stuck in chuck, unable to unlock it. Can you help
I would suggest contacting one of our Factory Service centers so we can take a look at it. Please see the link provided. DEWALT com
Mar 16, 2015 | Dewalt DC759CA 18-Volt Compact...
How do I remove the chuck from this roto hammer?
Most chucks are attached to the drill by an Allen head bolt.
To access the bolt spin chuck open all the way you should be able to see the bolt. Some bolts are a left hand thread so try loosening one way and if that doesn't work try the other direction.
After removing the bolt tap lightly on the chuck to help remove it
A little pentatonic oil is also helpful.
Bob
Mar 02, 2015 | Drills
We have a chuck that got jammedand broken, is it possible to remove the chuck only and replace it or do u only get the whole front section with chuck. And if the chuck can be removed, how do u remove it....
With the chuck open as far as possible, look within the jaws of the chuck for a bolt or screw head that attaches the chuck to the shaft. Remove the bolt/screw and remove the chuck. Some chucks can also be screwed onto the shaft, so look for signs of threads at the base of the chuck. Otherwise, once the bolt/screw is removed, tap along the outside around the chuck with a plastic hammer to loosen the chuck. Penetrating oil will help.
Take your chuck with you to a "big box" type hardware store, where a replacement should be available. Any well stocked hardware store should be able to help you. I have found that the somewhat smaller hardware stores are usually staffed with knowledgeable persons, and getting a replacement ordered is easier. One is more likely to be stocked in the larger stores.
The name brand of the chuck isn't as important for a replacement as is the correct shaft size and style of fit.
Best regards, --W/D--
Jun 15, 2011 | Chicago Pneumatic RP9790 STANDARD GRIP...
How to install an engine
the engine ofr the 95 Le Sabre is most easily taken out by dropping the sub frame. Here's how its done:
1. Lift the car on jack stands as high as you can get it **DO NOT FORGET TO CHUCK THE REAR WHEELS***
2. Begin by removing the battery cable, air filter hose and air filter box, the front wheels and disconnecting all the sensors from the wiring harness there are 2 main harness connectors that should take care of all the sensors depending on year and model. Also remove power steering pump and Cruise control.( this includes the starter cables and remove the A/C compressor* from the engine its self.
3. The next step is to remove the exhaust manifold that is bolted to the engine (trust me it saves about an hour of frustration, and saves you an exhaust gasket)
4. next get a hoist or engine crane strapped to the motor and support the engines weight. Then begin taking the engine cradle out by removing the 4 bolts out of the sub frame.
5. next lower the motor and trans mission from the vehicle. and pull it from under the car.
6. remove the transmission bolts (there are 5) that are at various circumference of the motor to trans
7. Now support the transmission and lift the engine off the engine cradle (sub frame) and replace the new engine into the old engines place.
8. bolt the engine to the transmission and replace the starter.
9. slide the engine back under the vehicle and replace the lift or hoist back on the engine.
10. lift the engine back into place and adjust the sub frame into place and bolt that back together.
11. replace the exhaust manifold.
12. replace the engine wiring harness, A/C compressor, Power steering pump, cruise control, and attach the starter wires.
13. reconnect the air filter hose and air filter box.
14. check motors oil level, and oil filter.
15.reconnect battery
*DO NOT DISCONNECT THE AIR CONDITIONING SYSTEM WHILE IT IS STILL PRESSURIZED!*
Apr 26, 2011 | 1995 Buick LeSabre
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
Mar 21, 2010 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
I need help replacing a bostitch framing air nailer trigger model 28ww it's leaking air and won't work.
follow closely, do you have a new trigger assembly because the problem is with one o ring commonly referred as the purple o ring in the kits? either way the procedure to remove the trigger is first knock out the roll pin for the trigger latch and then the 2 roll pins for the trigger assembly. next get a shop rag or equivelant and place under the now exposed trigger assembly and then while holding the collar on the air chuck plug into tool and hold rag tight and trigger will "pop" out pull the chuck away and remove the 2 pins to disassemble the assembly or install in reverse order lubricating the o rings first. Let me know if you have any questions or problems.
Nov 22, 2009 | Stanley Bostitch F28WWMCN 28° Industrial...
Remove and replace the chuck
Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
May 28, 2009 | Drills
Presure in raidiator
I know you said you did the head gasket, but it really sounds like a head gasket issue and pressure getting from the cylinder into the colling system. If you've had recurring overheating that necessitated another gasket replacement you'll likely have a warped head, which could explain the recurring t symptoms despite changing the gasket.
I'd do a compression test with the radiator cap off and see if you're losing compression. You'll likely need to have the head machined to remove the warping. Once machined and replaced with a good Yamaha brand gasket and a high temp sealant to help it, you should be okay. Be sure to torque the head bolts exactly in the order required and to the exact level required by the factory.
Hope this helps.
Dec 28, 2008 | 2006 Yamaha DT 125 X
Replacing factory radio
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is slightly tricky. Start by removing the trim around the shifter, its friction fitted so it will pop off with gentle force. Then you can remove the larger piece of trim that surrounds the shifter and extends up to the cup holders, I found that prying from the cup holder end seems to work best. Now you will be able to remove the trim that runs down the side of the center consol and includes the cup holders and power plug, you undo the 2 screws near the shifters then pry it off down the sides and pulls clear from the dash. Only then can you undo the bolts that hold down the bottom of the radio frame. From there it becomes alot easier. Push on the frame where you just pulled the bolts out of while prying gently at the radio consol. The whole thing will come out the factory unit comes out easily then you can put your dash adapter (schoche makes a decent kit) and aftermarket unit in.
Dec 11, 2008 | 2005 Honda Civic
Craftsman NEXTEC 11812 12 Volt Lithium-Ion 3/8-Inch Reversible Drill/Driver Logo
23 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
