Question about RCA Televison & Video
Drc99391 will not load dvd you can here it start and stop spinning . makes some clicking noises then screen reads no disc
    Top Expert:
  • RCA Master
  • 14,553 Answers
Usually if "no disc" the optical unit in the player is either dirty or bad.
If bad cheaper to buy a new unit as individual parts are not usually sold for this type of equipment.
Posted on Dec 08, 2012
silly girl
  • 513 Answers
SOURCE: dvd not loading
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens. This is assuming you get this with all disks, otherwise better not risk opening it. Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved. Anything else is for the lab(motor, lens assembly, focusing problems etc) Good luck
Posted on May 31, 2006
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
  • 6 Answers
SOURCE: Nexxtech N700-PD DVD Player - Discs will not load
Tracking motor has to be replaced
Posted on Jan 04, 2008
SOURCE: Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
Posted on Aug 19, 2009
  • 5 Answers
SOURCE: Audiovox D1998 Portable DVD Player will not load DVD
you need to clean the disc and make sure it fits in wright if that dose not work try another disc.
Posted on Sep 15, 2009
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Sep 15, 2009 | Audiovox D1917
Apr 22, 2009 | Audiovox D1917
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD player problem
you allneed to make sure the disc is spinning in the player you should hear it whirr as ut builds speed listen closely to it and keep a hand on it to feel when the disk quits if it starts. its supposed to spin v ery fast do you think you could tell by the sound of it if its spinning fast. some times they make a clicking noise because the drive mounts have slid down in the case and allows the disk to rub or tap the case. please let me know what you find out. this is for all three problems. let me know the results so i can further advise you.
Nov 26, 2007 | Cyberhome CH-DVD 300 DVD Player
EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
Jul 24, 2006 | Emerson EWD2203 DVD Player/VCR
Televison & Video Logo
55 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
