Question about IBM ThinkPad R40 2722 Notebook
PC won't wake up after Hibernate, Standby or Restart
If you place the PC in standby or hibernate or you do a restart - the PC just has a blank screen (won't boot up again). If you do a full shut down and then turn it back on - it will boot.
  • Anonymous Apr 13, 2009
    how is that supposed to help if you can't boot the thing up in the first place?
  • Anonymous May 19, 2009
    I've had the same problem, but only if I close the lid. I have to hold down the power button and do a warm boot, which is not good for the system. IBM had me reset my computer back to its factory state (yes, back things up and wipe out everything to start over-- what a pain this has been because things never go back quite the same). So, it worked again for a while at least and then the same thing stared happening again. IBM doesn't have an answer for me. If they tell you to reset it to factory state, good luck!
    Genius:
  • IBM Master
  • 1,102 Answers
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Posted on Jan 12, 2009
Standby/Hibernate
Have you tried or are able to use system restore to go back to a earlier date before this issue?
May 28, 2012 | HP Computers & Internet
I now use a verizon mifi card for my internet connection and after I put the computer on standby and wake it back up, I can not receive calls on Google talk. It still rings but the the Google voice call...
i believe its the standby causing the issue
try to change over to using hibernate instead which also saves more power
how to setup hibernate
  1. Go to Start->Control Panel->Power Options. Click on the Hibernate tab
  2. Click on the box that says "Enable hibernation" to check it.
  3. Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
  4. Restart your computer every week or so to clean your computer.
May 02, 2011 | Google Talk
Msi cr400 screen flicker problem
There is a big difference between hibernate and sleep mode. One will not wake just by opening the lid. You can get a full answer from this web site:
http://www.mydigitallife.info/2007/10/12/what-is-the-differences-between-sleep-standby-and-hibernate-in-vista/
I suggest visiting that site for a full explanation. It just might be the answer for which you are searching.
Good luck,
-a.
Jul 23, 2010 | Computers & Internet
My Samsung N10 is turning on from stand-bye by itself. Any solution?
Most likely you are touching the keypad or mouse and it thinks you are waking it up. You might try selecting hibernate instead of standby which will put it to sleep and won't wake up until you press the power button. If you don't have the hibernate choice you'll need to go into your power settings to enable hibernation.
Dec 17, 2009 | Samsung NC10-14GW Notebook
When I take the computer out of the standby mode
Try this:
  1. Update the BIOS and Video driver to the most current on http://support.dell.com
  2. Disable the screen saver
  3. Enable HIBERNATE instead of standby in Power settings, set the LCD to go off in 10 minutes, HDD to 15 and Hibernate in 20.
Select Shutdown, Hibernate
then try and restart
If no GO, disconnect all peripheral items except KB
Try hibernate again and restart.
If all works OK, add items back one at a time till you find item causing issue. If no go, replace power supply if issue still occurs, replace MB
Oct 13, 2009 | Dell Inspiron 530 Desktop Computer
Blank screen
Turn Hibernate off for one thing. Hibernation leads to registry problems and boot issues. Go to control panel > power options > hibernate tab > uncheck the box. Reboot the machine. If you want, the laptop will go into standby mode after a period of time and will wake up with a touch on the touchpad. Go back to power options and there are settings in there that you can tailor to your liking.
Sep 30, 2009 | HP Pavilion dv2000t Notebook
When I try to place my laptop on standby, it does
Go to the control panel, then power options. Go to the hibernate tab and ensure hibernation is enabled. Then, on the advanced tab, you can tell it how to enter hibernation :)
That should do it for you. If not, post a comment
Aug 22, 2009 | Computers & Internet
Dell crashes and restarts upon sleep_suspend_hibernate
I'm not a big fan of using hibernate or standby, I've seen it cause too many problems, such as the one you're having. I shut my machine down when I'm done, or let it run if I'm coming back within a reasonable amount of time. I've also seen hibernation or standby create operating system errors or glitches, and premature hard drive failure. If the machine is working properly other than hibernation/standby you should shut the hibernation off and just shut the machine down when not in use. If you're getting this error when using the power button to turn off the computer, then the operating system has glitched or is corrupt and needs to be reistalled. If you need anymore help with this let me know.
Jul 01, 2008 | Computers & Internet
Stanby mode
Goto control panel, performance and Maintenance, Power options, Power options property, hibernate tab, enable,apply, advanced tab, select how you want to stand-by or hibernate unit, apply.
Mar 17, 2008 | Toshiba Satellite A205-S4617 Notebook
Notebook utilities
If you are using Windows XP then go to Screen Saver tab of Display properties. There you can turn on hiberation under the Power Setting command.
The shortcut to it is when you click "turn power off' and you get Standby, turn off and Restart buttons. Now press the shift key, the standby button will change to Hibernate.
Feb 03, 2008 | HP Pavilion ZE4300 series: 1170B01-90...
IBM ThinkPad R40 2722 Notebook Logo
2,669 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
