Question about Toshiba E-STUDIO 650 Copier
Toshiba e-studio 550 call for service c010 - Toshiba E-STUDIO 650 Copier
5 Suggested Answers
  • 628 Answers
SOURCE: How to determine what error codes for failure on Toshiba E-studio
Press "Clear+8" and u will see the error code.
Posted on Mar 02, 2009
  • 628 Answers
SOURCE: my toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Posted on Mar 06, 2009
  • 628 Answers
SOURCE: my Toshiba e-studio 3511 gives me a C010 error,
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
Posted on Jun 24, 2009
Copier_God
  • 57 Answers
SOURCE: toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
Posted on Oct 16, 2009
Call service c010
Hi and welcome to FixYa.C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Thanks for choosing FixYa,
Aug 12, 2012 | Toshiba E-STUDIO 450 Copier
Call for service c010 how to solve it?
C010 indicates main motor problem...
U need to open up the back cover, perform output test to check whether the main motor is working. 03-101(ON)/151(OFF)
Dec 23, 2011 | Toshiba e-Studio 232 Black and White...
C010
Hi and welcome to FixYa. I am Kelly. C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Kelly
Nov 04, 2010 | Toshiba E-STUDIO 450 Copier
Que significa el error C010 en toshiba est 280 por favor alguien se lo sabe, gracias i.b
C010 indicates main motor is abnormal.
Is the main motor working? (Perform the output check in the test mode: 03-101/151)
If main motor working, check the feeder's clutch, whether it is hard.
Oct 23, 2010 | Toshiba e-Studio 350 Copier
Call service
error code c010.
What can i do now? Please send me a soliation.
Mar 06, 2010 | Toshiba e-Studio 350 Copier
Forgot password toshiba estudio 450
The default password is either 12345 or 123456.
If neither of those work then, turn machine off then power on while pressing the 0 & 8 keys then enter 263, then press Start. It will then display the Admin Password.
Oct 23, 2009 | Toshiba Estudio 200L Copier
Toshiba e-studio 550 call for service F10
Do the following.
Jul 22, 2009 | Toshiba E-STUDIO 650 Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
My toshiba e-studio 550: service recommended for SPC appeared
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
24 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
