Question about Kenmore Refrigerators
Bottom freezer works but not the top refridgerator.the fan behind the fridge works
Freezer door does not slide it opens the same as the fridge.The door seals are fine.It does not have an ice cube maker.Here are the numbers on the back of the fridge---596.68142891---MFG P1317002WW---SN 9803184765.No air is blowing inside of the fridge
  • 1462 Answers
SOURCE: freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Posted on Apr 09, 2007
catriver
  • 878 Answers
SOURCE: Freezer works fine refridgerator does not
anan, I think your display is giving you a code on these LG. See if you can find the tech sheet behind the toe panel. On your display panel from memory, 3 led's lit from the left means a failed defrost thermistor. This could be the reason you are frosting up and restricting the air flow. There is a main board in back that you can ohm out the thermistors. Connector 4, the two bright orange wires #5 and 6, should ohm at 19K ohms at 50 degrees. Now Im doing this from memory, if you can find your tech sheet, it will give you precise information. Catriver.
Posted on Jun 14, 2007
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
Leveling a refridgerator
if not level you need to tip it back and unscrew or screw in the feet on it. use a 2ft level on top to be sure which way to go. if just the door, open door and there is a bracket in between the freezer and fridge and it should be adjustable a little bit. unscrew til lose adjust door to right spot and hold while tightening bolts. that should work. if the fridge door is on top and freezer is on bottom then adjust bracket screws on top of fridge.
Jun 24, 2012 | Stainless Cal Flame Refridgerator Steel...
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Refridgerator and Freezer Not Cooling (2 year old fridge)
Some of these had problems with the door light switches between the doors. They also control the fans. The top and bottom both have fans in back. Try opening top door and holding door light switch in. Wait for a couple minutes to see if fan comes on. Try with freezer too. If not coming on may need switch.
Jun 02, 2010 | Samsung RB215LASH
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refridgerator is only cold on the bottom. Fridge is a side by side and both sides are doing the same thing. Top shelves are not cold or freezing, but the bottom ones are. What is causing this?
Good day,
The common reason for this is the fan motor behind the rear panel in the freezer compartment is not running.
With the machine on and running, open the freezer door. You should hear the fan running.
If not the motor can be accessed by removing the rear panel in the freezer compartment.
Replacement is a nuts and bolts operation.
Dec 17, 2009 | Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Condensation in refrigerator even in the morning
Are the temps in the fridge and freerzer as cold as they should be? The air circulates through the unit and the moisture is taken out in the freezer by the evaporator coils. If they are not cold enough the moisture won't be taken out. The freezer fan has to run to do this and the damper (vent) between the freezer and fridge has to be open. A door not closing good and leaky door gaskets will cause excess moisture.
Aug 19, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
