Question about Dryers
Kenmore 8000 series electric front load dryer vibrating
Just moved in to a new place and the dryer vibrates very bad. Still dries, and checked lint from front and back. also checked pulley and belt. still cant determine what is needed.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check the drum rollers. Sounds like one is bad.
Posted on Dec 08, 2012
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer won't start. #63841
Normally when a dryer starts to exhibit longer dry times, then suddenly stop working, it is an indication that the Thermal Cut-Out has blown. The TCO acts as a fuse for the heating element circuits. When an overheat condition occurs, normally the hi-limit thermostat will open to shut off the heating element. This is how the dryer regualtes its heat. However, if the hi-limit thermostat malfunctions, the TCO will blow, It is not resettable, and has to be replaced. This also means that the hi-limit thermostat could be suspect and it should also be replaced at the same time. Normally, when you go to replace one or the other they are sold as a set. This still does not rule out the possibility of a bad heating element, either.
However, you said the dryer additionally does not start. With a blown TCO or heating element the dryer will still run, but will not heat. I'll get back to this in a minute...
Now...if your dryer has been having problems drying, the first thing you need to check is the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This could be the "electrical" smell you've experienced. If trapped lint is ending up on the heating element it will smolder and burn. I recommend the ducting be cleaned thoroughly about once per season. That's 4 times per year. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. One way in determing air flow is to remove the vent hose from the back of the dryer and start the unit (of course, you need a working dryer in order to do this). The air should be forceful and slowly warm up to about 140 degrees. If the air flow is weak, you may have a clog inside the air baffle of the dryer (this is where the lint screen slides into). If the air flow is good, reattach the dryer hose and check at the output of the dryer vent as it exits your home. If the air flow is weak or non-existent then you know you have a clog in the vent line somewhere. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint.
Now, in determing which component is bad in your dryer. If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side.
The heating circuit is set up and troubleshot as follows:
Heating Element (located inside the heater box) - Resistance reading should be 9-13 ohms.
Thermal Cut-Out (located on the heater box) - Resistance reading of 0 ohms.
Hi limit Thermostat (located on the heater box closest to the heating element leads) - Resistance reading of 0 ohms.
Operating Thermostat (located on the air baffle) - (May have 4 wires attached to it). Will read 0 ohms across one set of leads, 7 ohms across the other.
*Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms.
*If the Thermal Fuse blows, this will shut down the entire dryer. This is your likely suspect.
Here's a few things that will cause a dryer not to start at all:
1. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
2. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
3. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
4. Bad Timer - If the timer does not function the dryer will not start.
5. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
6. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
I just threw in those other items to give you some other things to consider. Troubleshooting is always an exact science as symptoms don't always indicate what you think the problem could be. The reason I keyed in on the heating circuitry was the intial symptoms you started with. Longer dry times are usually associated with poor air flow which usually causes something to eventually blow. I hope you find this information helpful. Please post back with any comments that I may assist you further. I hope this isn't confusing to you. Please ask for clarification if it is.
Posted on Nov 02, 2007
docjohn174
  • 943 Answers
SOURCE: Kenmore Series 80 electric dryer
hi. i will send you to .repair clinic. go to dryers and belt diagrams. sorry i cant send you one. if you have any trouble, get back to me the appliance doc
Posted on Oct 02, 2008
mark_37388
  • 100 Answers
SOURCE: I NEED TO REMOVE THE FRONT PANEL OF MY KENMORE 8 SERIES GAS DRYER
One of two ways depending on oh made this unit GE or WPL FIRST look at the top of the door opening for two screws if there is no screws get a flat head screw drive and look with a flash light between the top and front pane you should see a clip about 2 inches from the sides going tworge the middle use a flat screwdriver place in the crack between the top and front panel and hit the back of the screwdriver with you hand should push the clip back an the top pop up do the same onthe other side (before you start if you lent filter goes in the top of the dryer remove the two screws holding that down to remove the front in the side panel going into the front is a screw on both side remove then lift the front up too unclip the bottom clips good luck.
Posted on Mar 30, 2009
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
  • 57 Answers
SOURCE: Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Posted on Jun 20, 2009
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
How stop front loading electric dryer vibration while drum is rotating clothes.
110 means you have a whirlpool dryer. If the filter is on top then I would say you have a bad glide, if the filter is in the door you have a bad wheel, very rare. At any rate you need to open it up and inspect it.
Videos and more on kenmore dryers
Mar 06, 2012 | Kenmore Dryers
Maytag electric dryer model MDE6000AYW dryer is running but not getting hot and drying clothes plus making a dining noise every couple seconds while running
Dryer Does Not Run
Your Kenmore Oasis dryer may occasionally not operate as intended. When the dryer does not turn on, check that the power cord is plugged into a working electrical outlet. Check your fuse box to make sure a fuse hasn't blown or the circuit breaker hasn't tripped. Replace the fuse or reset the circuit breaker as needed. Next, check that you have fully closed the dryer door; if not, the dryer will not run. Finally, make sure that you press and hold the "Start" button for at least five seconds.
Dryer Making Noise
Kenmore Oasis dryers will make noises that occur commonly with the running of the machine, including the motor and the sound of hot air blowing into the machine. Listen for uncommon noises with the running of the dryer, such as metallic clanking and excessive vibration. These noises indicate a problem with the machine.
If you hear metallic clanking, stop the dryer and check for any metal objects in the dryer drum. Often, change or other objects left in the pockets of clothing placed in the dryer will then fall out when the dryer starts spinning, creating the noise.
Excessive vibration often occurs when you have not properly leveled the dryer. To check whether the dryer is level, turn it off and try shake it frontward and backward, then left and right. If the dryer moves, adjust one or more of the legs needs to level the dryer: Determine which leg(s) you need to adjust and use a wrench to lengthen or shorten the legs. A level dryer will more quietly due to the elimination of vibrations.
Drying Time is Too Long
You may find that your laundry takes a long time to dry in the Kenmore Oasis dryer. This often occurs due to restricted the air flow within the machine. First, clear the lint filter. Clean it before every drying cycle to ensure proper air flow through the machine.
Next, run the dryer as usual and check the exhaust vent to ensure that airflows out of the vent. If you cannot feel air flowing through the vent, check it for blockage or damage. Clear any objects blocking the vent, or replace it if it has sustained damage.
The blockage may also occur in the exhaust hose attached to the back of the dryer. Unplug the dryer and remove the hose from the back of the machine. Clean out any lint or other obstruction and reattach the hose to clear the exhaust hose.
Mar 09, 2011 | Dryers
Won't dry clothes
Try running the dryer with the vent pipe unplugged. There should be a lot of hot air coming out, if not the insides need to be cleaned. If it really moves air, and dries a load ok unhooked, your vent is clogged. Clean it if you can. If you can't, look into a lint trap that will work for your situation, some have a water trap, some are good filters, etc. If the air is not hot, some of the electric element may be bad. If it's gas, it could need a tune up and cleaning inside.
Apr 24, 2009 | Kenmore Dryers
Intermittant buzzing vibration like sound when drying.
Check your lint filter may have lint filter alert.
Apr 22, 2009 | Roper REX3614KW Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Laundry appliance installation
not recommended may cause vibration issue.. my preference ? concrete or tile especially on front loads
Aug 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer just stopped working??
replaced thermal fuse and working like new
Apr 08, 2008 | Kenmore 62602 Electric Dryer
IF THERE IS A RESTRICTION IN THE EXHAUST(LINT BUILDUP OR FOLDED FLEX ATTACHED TO THE DRYER AND PUSHED UP AGAINST THE WALL) THE DRYER WILL NOT DRY PROPERLY. IF THE PROBLEM IS NOT FIXED, A THERMAL FUSE WILL OPEN SHUTTING DOWN THE CIRCUIT TO THE MAIN MOTOR. THE THERMAL FUSE IS A SMALL WHITE OBJECT LOCATED BEHIND THE BACK PANEL DOWN BY THE EXHAUST OUTLET. THERE ARE TWO WIRES ATTACHED TO IT. IF IT IS BAD, REPLACE IT AND CHECK THE DUCT WORK FOR ANY RESTRICTIONS.
PART COST APPROX 30 DOLLARS
Mar 31, 2008 | Dryers
Clothes taking VERY long to dry
Is it a gas or electric dryer ? try to do a full load without the lent tube hooked up it might be clogged with lint. if that doesnt work then let me no if it is gas or electric then i can help you more
Aug 28, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
