Windows media won't sync music
Says device is full and it;s empty
  • Anonymous Mar 01, 2009
    my mp3 has more than enough room on it but will not sync. it will say syncing progress has been stopped
    Problem Solver:
  • 8 Answers
Reformat the hard drive.
Posted on Jan 12, 2009
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
28
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
Fallen at the first hurdle! The instructions say it's easy!!
try going to windows media player and going to the sync tab. connect your device, than what ever music is in the liberary of the media player, drag it to the sync list. when you have the songs you want, click start sync. thats what i did with mine.
Mar 15, 2010 | SanDisk Sansa Clip MP3 Player
Want to replace existing music on Sansa e280r
While it is unplugged, go to Settings on the Sans.
Go to USB mode and select MSC
Connect it to computer.
Open device through "My Computer"
Go to Tools
Select Folder Options
Select View Tab
Select Show Hidden Files and Folders
Press OK
You should now see the Music Folder
Delete what you don't want.
Sep 23, 2009 | SanDisk Sansa E280 MP3 Player
Player doesn't display the music that is synced on it
maybe you don´t get the right format on the music you put on your device sometimes you need to convert the music archives to mp3 before you put in
Mar 06, 2009 | Audio Players & Recorders
Can't delete music or load music on my sansa e250r 2.0
In your windows media you will see the device name listed..you have to make sure the device is under MTP mode..then click on the player and you will see all the songs...you can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
May 15, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
HELP ME PLEASE with my "sony walkman NWZ-B105F MP3 PLAYER."
make sure your downloading it to the right folder on the mp3 player its usualy the music folder or you can try and use windows media player here are some instructions for that option.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Apr 12, 2008 | Sony Walkman NWZ-B105F MP3 Player
Windows Media Player won;t sync music!
Turn off the automatic sync option - change it to manual sync, and then you should be good to go. Change to manual sync first, and then reformat.
Apr 09, 2008 | SanDisk Sansa e260 MP3 Player
Unable to sync music
What happened when you tried to sync? it could be a device certificate error...what i would recommend you to do is to sync using your windows media player...assuming that you have windows media player 11...open up your windows media player and click on sync..then you can drag the tracks you want to sync and then click on start sync...if you are not able to transfer the songs to it..use a song that is not from yahoo like the sample one that came with your computer and see what happen...if that doesnt solve the problem check your usb mode..it should be under MTP mode or auto....then open up your windows media player and format the device there...after you have done that..that should solve the problem you are having..let me know what the outcome is....
Jan 06, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Windows media does not load music
Mario here < cy >. the support for the device from windows is in two parts. The mtp driver and the device usb driver. if you have the factory cd just follow the instractions and you must have xp sp2. I had the same problem. but the media player 10 from the cd is different from some others. . if your computer recognise it try for SURE imesh. it is free and full compatible with allmost any portable device.. (or you can just browse it)
Jun 01, 2007 | Samsung Yepp YP-T7JX MP3 Player
214 people viewed this question
 Grubhead
Grubhead
