Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water is leaking on floor from left hand front corner (freezer side) I noticed it does it on the right hand corner at times also
It doesn't do it all the time...sometimes there is more water than other times.
Started with the blow dryer, but water was still not coming through, poured boiling hot water, it would only drip into the pan, taped together straws (about 6) and pushed them through. A blob of dirt, dust or algae came out into the pan and then the water flowed freely.
Posted on Apr 30, 2013
  • Peggy Anderson Jun 02, 2013
    I poured boiling hot water into defrost drain tube then put a little bit of bleach into tube and it opened up the tube,,now it drains into pan...no more water on floor.
On my fridge like this one, on the freezer side, down at the bottom (below the doors, where the vents are, there's a turn knob there. If you turn it counter clockwise, it'll unscrew filter. It's white and about 2" round and 10" long. It's the filter that goes to the water supply and ice maker. Mine had stopped up, I just pulled it out, went to home depot and got another just like it and re-plugged it in.. No more leaks for me!
Posted on Dec 08, 2012
Question: I have two door refrigerator: Frigidaire (Electrolux) Model: FRS26R4A, has more than two months that leaves plenty of water for the bottom and I have installed water connection so I do not understand from where this water. This is more or less twice daily thaws is a little ice water and cold boot also freezes Fres Ford
Posted on Jun 02, 2013
4 Suggested Answers
  • 358 Answers
SOURCE: Water on floor and ice on freezer bottom
The problem is that the drain hole inside the freezer in the lower back wall is clough and the water from defrost doesn't go through that drain to the evaporative pan in the back by the compresor ,you need to clear thatdrain first meltting the ice in that hole with hot water until it goes through then once in a while (every 3,4 months put bleach into the drain to keep it clear .
Posted on Apr 22, 2009
woodchuck789
  • 4059 Answers
SOURCE: Leaking from left corner GLD2250rd Frigidaire dishwasher
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 08, 2009
heatman101
  • 43501 Answers
SOURCE: FRT16CRH Top Freezer Frigidaire
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 04, 2010
Why is my acer touch screen laptop messed up? It only got a Little bit maybe 5 little drops of water & i took them off right away. But when i swipe the screen the middle gets all scratchy. It...
Depending on what you wiped it off with? Paper towel, Bad. Microfiber cloth for computer screen, good. Shut down the machine, unplug, remove battery, Use the proper cleaning fluid and Microfiber cloth to clean. OR, this: http://www.amazon.com/3M-9027-High-Performance-Cloth/dp/B00006IBLQ
Feb 01, 2013 | Computers & Internet
I can't depend on it working, sometimes it is great other times it doesn't light.
Intermittent operation is usually a "Flow" problem. Water needs to circulate at a certain amount of water per minute. Most problems are due to restriction of water flow.
Most common problem = Dirty Filter
Backwash on a regular basis for starters.
If a sand filter, sand needs to be replaced on average every 7 years.If a DE filter, then you may need to completely break down your filter and manually remove & clean the grids. Then at reassembly, add the proper amount of DE back into filter by introducing via the skimmer.If a Cartridge filter, then complete break down and manually cleansing the elements. Possibly replacing them if they are older than 4 years old.
Dec 17, 2012 | Pentair Minimax NT Heater
What do i do when my compaq keyboard dont work?
if the keyboard is plugged in to the computer correctly, & it still doesn't work then it's time for a new keyboard, it's like any other part of the computer sometimes even the keyboards go out
Feb 02, 2012 | Computers & Internet
1992 Lexus S300 Automatic. Car drive perfectly fine. Problem is sometime when I start the car, it should idle and shut off within 5 seconds. Doesn't happen all the time, just sometimes. Sometimes it d
Without any other symptoms it is hard to diagnose; could be water in the fuel or a plugged up air filter, that effects idle first, take it out and see if it idles fine, if so get a new one. Take out fuel filter and dump in a glass bowl and analyse for water... get a new one... Is it different when the engine i hot or cold?
Dec 05, 2011 | Lexus SC 300 Cars & Trucks
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Aug 29, 2011 | Necchi Sewing Machines
Oven temp is inconsistent. Sometimes it works but most of the time it doesn't. Yesterday we set it at 350 degrees. Two hours later it only came up to 250 degrees. I've replaced the oven sensor but...
Is this a gas oven? gas ovens rely on ignitor/glowbar ignition. The system uses amp draw to open the gas valve. If the ignitor is off a tad in amp draw then kickin or bangin on the stove sometimes makes that puppy work.
Jul 20, 2011 | Kitchen Ranges
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Frigidaire FRS26R4A Side by Side Refrigerator Logo
582 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
