Why does my computer say no imput signal - Computers & Internet
  • 27,725 Answers
If you have used a desktop computer or have a dual-monitor setup, you have likely seen the "No-input Signal" error message on your computer monitor. The error message may point to a number of culprits. Accordingly, the solutions run from simple to complex. Prior to attempting advanced troubleshooting methods, check the connection first. Power off the computer and the monitor. Remove the cable that connects the monitor with the computer, then reseat it. Try a different port, if possible, then reboot the computer.
Connect the monitor to another computer if possible to eliminate the monitor as the faulty hardware. Shut down the computer. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove all cables and devices plugged into the computer. Make a note of the port into which your monitor is plugged. Remove the left side panel when facing the front of the case. Unscrew screws or manipulate latches to remove the side panel. This process varies according to the type of case you have. Please consult your manual if you are unsure of how to remove the side panel. Attach the antistatic wrist bracelet's clip to a metal object, then ******** the bracelet. Locate your video card. (This will be the card that contains the port with which your monitor interfaces.) Remove the slot cover screw that secures the card into the slot. Remove any power cables that connect the video card to the power supply. Pull the card out of the slot. Examine the gold pins to check for any damage. Reseat the card if it physically appears to be undamaged. You should hear a click once the card is secure in the slot. Screw in the slot cover screw. Attach the power cable from the power supply unit, if applicable. Leave the case open for now. Reconnect only the monitor, power cable and any devices required to boot the computer, then restart the computer. Shut down the computer again if you receive the "No-input Signal" error message again. Remove any cables and devices you plugged in to restart the machine. Remove the video card with a spare or replacement by following the instructions above. Connect necessary cables and devices to reboot the computer, then restart it. Shut down the computer and remove cables and devices if the display still won't work. Unplug the power supply's cables from all devices on the motherboard. Make a note of each plug-in so that you can correctly connect all devices with the new power supply. Remove the screws that mount the power supply. Fit the new power supply into the mounting area, and screw in all screws. Attach all required power cables to devices connected to the motherboard. Attach the cables and devices required to start the computer. Reboot. Hope this helps.
Posted on Dec 07, 2012
No signal on tv screen
Is it registering the correct input? HDMI/ AV1/ AV2/ SCART!
Nov 05, 2014 | Televison & Video
Po715-imput turbin speed
The code means the input speed sensor in the transmission is not sending the correct signal to the computer. The sensor would need to be tested.
Sep 03, 2012 | 2002 Mitsubishi Eclipse
Keeps telling me no imput signal
Make sure that all cables are securely fastened, and that the monitor is set to use the correct source (eg. DVI, VGA, or HDMI).
Feb 28, 2011 | HP w1907 LCD Monitor
Recieved "No Signal Imput" after relocating computer and monitor
You need to check VGA cable connections at both ends, check video card to make sure it is seated properly in to the PC slot, etc. Try this monitor with other PC as well.
http://s807.photobucket.com/home/budm/allalbums
Apr 22, 2010 | NEC 17" 1700V TFT LCD Monitor 1280X1024...
Monitor green light comes on then it says no imput
looks like there is problem with ur signal cable check that monitor signal cable is tightly fixed or contact ur product support center.
Mar 31, 2010 | HP Pavilion F1523 15" LCD Monitor
No Imput signal moves on screen instead of screensaver
cb5547, Do you SEE the strange "no signal""no input" messages when other programs are running such as MSword, Excel, IE8, ? I would guess that when very strange things begin to occur "ON SCREEN" of an LCD display, that something might be about to go bad in the unit's power supply. In any case a technician should evaluate it for you. In the mean time hook_up (swap-in) a working monitor to prove that your PC is working correctly. report back here with a new comment on fixya and I will suggest a few things you can try. I'm 12fixlouie
Nov 07, 2009 | HP w1907 LCD Monitor
No input signal
Make sure that the correct cable is used vga to vga or dvi to dvi..... try some different cable.... try a monitor slf test you cannot access it by just removing the monitor cable..... if do get the test the monitor is bad
May 02, 2009 | Computers & Internet
Monitor says "no imput signal"
Check video card in the computer by buying a new video card or used one your choice, if this does not shore it up the its the motherboard itself.
Thanks
Monitor malfunction, says VGA Input: No Signal and goes to sleep
from what you have described it appears that the onboard video might have malfunctioned,there is no way to replace it, you can however go buy a video card from your nearest computer retailer. you just want to make sure it is compatible with your machine. on another note from what your saying the keyboard is donig i would be wary about spending to much $$ because it could also be your motherboard
Apr 23, 2009 | Computers & Internet
Lcd to pc
YOU MUST GO INTO YOUR COMPUTER CONTROL PANEL TO SET THE DISPLAY SETTINGS FOR YOUR LCD.
Sep 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Computers & Internet Logo
David Payne
David Payne
