Question about Mitsubishi WD 65837 65 in. HDTV
Mitsubishi wd-65837 blue screen
I have mitsubishi wd-65837 and now all input sources projected as a blue screen. I tried to reset the input sources and hard reset the TV and reset the menu to manufacturing setting but still i am getting a blue screen no matter what i do. I need help
SOURCE: Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
Posted on Aug 05, 2007
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
SOURCE: Mitsubishi LT46-144 LCD Verticle Line Problem
Go to Mitsubishi support page, look at warranties (scroll down) and see if your model is under the extended warranty section. Then if so have a tech repair person come look at the picture and order the parts while you keep the tv. Parts and labor are covered.
Posted on May 19, 2009
SD Tech
  • 14553 Answers
SOURCE: my mitsubishi projection tv, ws55813, was losing
There is a hard reset you can try on this set--it is done with the Mitsubishi remote that came with the set.
Confirm actual model number and I will tell you how to try it. The set will shut off after the reset(not the reset button some of these sets have on the front) and come back on channel 3 in the air band--any labels for inputs will be replaced by original input numbers etc.
No guarantee this will fix your problem but it will return the set to the condition it was when new in the box.
Let me know if you want to try this.
SD TECH
Posted on Oct 25, 2009
  • 8457 Answers
SOURCE: I have had my Mitsubishi WD 65837 for about 6
Take ur warenty repair,problem with ur backlight video board.
Posted on Dec 15, 2009
I have mitsubishi WD-65837. TV is auto-sensing an input change from the Receiver and then changing the activity automatically on the TV. How do I remove the inputs/activities, and lock in 1 input?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 27, 2017 | Mitsubishi Televison & Video
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
RESET Mitsubishi WD-65837
The set aside from a reset button recessed on front (some do and some do not) has at least 2 hidden menus= adjustment and OPTION MENU---option menu will do a hard reset of the entire set---but it requires a 4 digit number code by model---being 1500 miles away from my paper files I have a suggestion.
You can search to see if can find (I strongly doubt Mitsubishi will tell you) the entry code for your model.
Some of these sets also had a soft reset (no harm trying) and it is with the set turned on and using the Mitsubishi remote (also needed for hard reset) Menu, 1,2,3 enter.
That ought to be at least tried and the OPTION menu is usually last resort here---
SD TECH
Apr 19, 2012 | Mitsubishi WD 65837 TV
Wd-73737 wont turn on blinking green light
First is if you are able to get it to turn on and blue screen only appears it will shut down as no signal noted.
If you can get it on with Mitsubishi remote : Menu, 1,2,3 enter
This is the soft reset and the set also has a hard reset.
Try the soft reset first and let me know what happens.
Mar 09, 2012 | Mitsubishi WS-55613 55" Rear Projection...
WD 52725 won't accept INPUTS
the most probable cause are the capacitors have failed on the terminal 1 and terminal 2 PWBs or the signal PWB
May 18, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Blue screen on tv
DID YOU TRY TO CHANGE THE CHANEL MANUALLY? OR CHECK THE INPUT BUTTON
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 65837 65 in. HDTV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
