Question about Hitachi NR90GR Cordless Round Head Gas Framing Nailer
Fan is constantly - Hitachi NR90GR Cordless Round Head Gas Framing Nailer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
I deal with more paslodes but think Its the same concept... Theres a button/switch on the trigger and back cap... the back cap one turns on the fan when the tool is depressed and the trigger one fires the spark to ignite the gas.
Seems like the one on the back cap at the rear of the cylinder is stuck on.... or theres a problem with the circuit board
Posted on Dec 09, 2012
Minka fan light blinks constantly
Are you using the correct wattage?
Feb 11, 2014 | Minka Aire Ceiling Fan
Mercedes C180 W203 coolant fan on constant
The fan is on because the wire is cut. If the ecu does not detect a signal from the fan switch it will default as on. Replace the wire and fan temperature switch and all will be ok
Nov 02, 2012 | Mercedes-Benz Cars & Trucks
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
My fan is running constantly computer seems
Yes, the fan should run continuously else the processor will get toasted. It get very hot without the fan even when the PC is not doing anything visibly.
Dec 15, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
My mdx 2002 acura fan blows constantly and kills my battery.
You most likely have a sticking fan control relay.
Remove the relay to confirm fan stops.
Aug 19, 2009 | 2002 Acura MDX
Goodman a/c blower runs on auto and humidity problems
Is the air cold inside? You are talking about the fan inside? Have system check for freon but more than likely, it sounds like a t'stat problem. And it's not normal for the fan to run constantly.
Jul 05, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan runs constantly
one reason that a CPU fan may be running constantly is that it may not be able to cool the cpu down. usually this could be due to dust or debri clogging the incoming or outgoing vents or even dust accumulated on the fan itself or the heatsink.
Jun 03, 2009 | HP Pavilion a1110n (PX743AA) PC Desktop
Fan / Compressor runs constantly
Condenser fans (the fan next to the compressor) do run all of the time. That is normal.
Sep 18, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Hitachi NR90GR Cordless Round Head Gas Framing Nailer Logo
105 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
