Question about Cub Cadet Garden
Compression relief on cub cadet mower lt1045
Show compression relief for starting engine
  • 109 Answers
SOURCE: Engine on Cub Cadet lt1045 stopped and now only
If this is Kohler engine...
and the battery is good, volts and amps...the compression release on the exhaust cam gear may be broken.
If so, the cam gear must be replaced
Posted on May 06, 2009
  • 93 Answers
SOURCE: Cub Cadet 997 self propelled mower with 6.5
Might be just a loose head, Check that first, are the bolts tight? If loose I would clean head and install new head gasket and torque to specs. (In inch pounds).
Posted on Sep 17, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
  • 78 Answers
SOURCE: How do you remove the front tire on Cub Cadet
Thats a plastic dust cap.Remove it very carefully so not to damage it. Then under the plastic cap will either be a Cotter pin or and E clip remove what is there and slid the tire and wheel off the spindle. These are a bear to break down and dismount and or remount. Unless you have a mini tire changer. I use my huge vise and a shaft the size of the spindle.I use motorcycle or bicycle tire irons. ITs a hassle believe me.
Posted on Oct 22, 2009
mowerman1857
  • 389 Answers
SOURCE: Cub Cadet LT1045, suddenly stopped, (driving
Locate and check the fuse, replace if necessary. Check battery terminals especially the ground, clean and tighten as needed
Posted on Oct 30, 2009
Testimonial: "you are correct sir,,, finaly saw in the parts list that there was a fuse, ,,,, after a bit of searching I found the fuse and it was blown"
Troubleshooting
maybe bad sending unit most likely or bad oil pump
Jul 31, 2014 | Cub Cadet Garden
Solenoid clicks cub cadet lt1045 mower won't start. Has new solenoid, starter battery and spark plug
It is possible the starter safety circuit is triggering. This is an interlock to prevent injury when starting and checks for things like driver not on seat, park brake engaged, etc.
Refer page 12 of the manual available on this site if you do not have one.
http://data.manualslib.com/pdf/4/341/34016-cub_cadet/lt1045.pdf?6c17c6482511338711d5965e5bb6681c&take=binary
Apr 23, 2014 | Cub Cadet Garden
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I don't want to talk to an expret , I lost my manual and I need one to repair my Tractor Cub Cadet lt1045
OK, I won't talk :)
Here is the direct link: http://www.hammerwall.com/Download_Manual/13295/ if the link gives you problems do the following.
Go to www.hammerwall.com and put in Cub Cadet lt1045
Jan 14, 2011 | Cub Cadet Garden
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Engine on Cub Cadet lt1045 stopped and now only turns 3/4 then drags and then frees for 3/4 then drags etc. What could be the issue
May 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
23 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
