Question about Refrigerators
Kenmore 106.78202890 Ref. Icemaker seems to work fine. No water leaks when it fills but I have water in the refrigerator section that seems to be draining from the freezer. Any ideas?
  • Refrigerators Master
  • 8,220 Answers
Hi there, I believe you may have a defrost drain problem. See the water has to drain somewhere else when the drain is stopped up. So instead of into the catch basin on the bottom of the frig it cascades down the backside of the frig and ends up under the crispers. To fix the problem you must clear the defrost drain. It is located beneith the evaporator coils. When the frost on those coils melt it turns to water. Remove the freezer access panel, and clean out the drain. Use some hot water or a shop vac.
Posted on Jan 12, 2009
  • Dan Webster
    Dan Webster Jan 22, 2009
    wow thanks for letting me know
About once a week I find a small puddle of water on my floor in front of my Kenmore Elite refrigerator (bottom freezer, no ice maker). What should I do?
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
Oct 02, 2011 | Kenmore Refrigerators
Kenmore side by side refrigerator leaking when trying to get water
Leo Ponder
imufo2
Sep 27, 2011 | Refrigerators
Leaking water as water line is broken. where does the water line go so I can replace it. I took the back off and notice the line has broken due to heat and age
Leo Ponder
imufo2
Sep 27, 2011 | Kenmore 57029 Side by Side Refrigerator
I have a kenmore ref. Model 795.7757 with error codes ER IF. The ice maker does not work and the temp inside the ref seems warmer than it should be. The freezer is also not cold enough. Please advice....
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 22, 2011 | Kenmore Refrigerators
We have a mf12568aeb refrigerator. the problem is it leaks water. water seems to somehow make its way into the freezer, which is in the bottom of the refrigerator and then runs out through the bottom of...
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
Leo Ponder
imufo2
Sep 17, 2011 | Whirlpool Refrigerators
Kenmore Elite bottom freezer, model number 596.76522500, Serial Number 10310256GL. Water dispenser on the inside left of the refridge. Water dispenser is not working, items are frozen in refridge. Ice...
Leo Ponder
imufo2
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
After an extended period of non-use, i attempted to start using my fridge again only to have the fridge section not get cold. the freezer section works fine, but fridge will not get cold. what do you...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
If
Leo Ponder
imufo2
Aug 25, 2011 | Refrigerators
I bought kenmore trio bottom freezer 2 years old, everything works fine, until one week ago, the fridge part becomes freezer, it frozen all the food, even I set temperature to 45F on the fridge.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 22, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Hello! I have a Kenmore refrigerator model #10656576400. It stopped making ice for a while but then started up again. Now it is leaking water and filling up the tray underneath the ice cube mold. Is it...
The first thing to check would be the water fill valve located usually on the back outside of the unit where the water line comes in, these can start leaking water slowy into the icemaker. The icemaker itself tells the valve how long tostay opened, that can be adjusted by a tech or you may need to replace the icemaker
Jun 24, 2011 | Refrigerators
Kenmore 10670187000 Refrigerator. freezer filling with water/ice
You pull it out from inside the freezer but I would try melting any ice that may be stopping it up first with a hairdryer. The water inlet valve on the back of fridge is probably leaking and when the water gets to to fill tube it freezes and partially blocks the tube causing it to spray out. Disconnect the line coming out of the water inlet valve to see if it has a slow leak. You may need to replace the valve.
Sep 03, 2009 | Refrigerators
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
