Question about Panasonic TC-2119R 21" TV
Power supply is not ok?
No video? main power is ok,
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
In a standard set the power supply produces one large voltage and a few smaller ones---if the High voltage circuit comes up it creates the rest---this answer is based on the description that this is a set with a picture tube and not a LCD set.
Posted on Dec 08, 2012
Samsung tv MODEL UN40F6300AFXZA
Please un-plug the cable between the main board & the power supply board, apply AC power to the TV, if the back light come on, that means the back lights & the power supply are OK, then you need to replace the main board; if the back lights does not light up, mostly the back light LED strip(s) is bad.
May 24, 2017 | Samsung Televison & Video
I put a new tcon board. Still no picture what's next the main board or power supply
Check the power supply output, if it is ok then I would try the main board, but if you are guessing you can still spend more and get no working TV
Feb 02, 2017 | Televison & Video
No power at all going to the tv when plugged in, no lights, no clicking, nothing - would replacing the main board fix this tv?
Check the power supply first. If its ok then only you have to buy a new main board. watch the video to know how to check the power supply. If you find its faulty then replacing the same will solve your problem.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Sep 09, 2015 | Televison & Video
NO POWER AT ALL
Hi
our tv set need to be serviced. Here are some tips:
1. Open main fuse. The fuse is clean but interrupted. You can try replacing it with one o the same value.
2. Fuse Blown or blackened. Short in the rectifier bridge or in the switching transistor. Out of the power supply: supply line rectifier (100/150V) shorted.
Sully
Sep 29, 2013 | Televison & Video
Sony kdl-52s 4100 power supply ok but no sound and display
Well, if the power supply is in good working order, you will need to verify that the proper voltages are getting to the main board. If the main board is getting the proper voltages, I would bet you have a defective main board. The video and audio signals are generated on the main board. Expect to pay $100-$150 for a replacement main board.
Nov 24, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Ps3 wont turn off just makes 2beeps when i press the power off
would has to open the unit and check for bad power supply , if the power supply is ok ( no bad capacitor ) the problem would be the main pcb or the hard drive
Feb 08, 2012 | Sony Playstation 3 (PS3) Console
I have done all that you saud to do. Now the problem I have is the computer will not turn on at all. It's like the power has been turned off from inside the operating progam. I have windows 7, is this...
Phase 1
After power button pressed, computer will detect 5 components :
1. Power supply - OK (enough power)
2. Main-board - OK
3. Processor - OK
4. Memory - OK
5. Video Card / VGA - OK
== beep sound .. (1 time) or on the monitor, display appears BIOS ==
The characteristics of damage to power supply
1. Power supply fan does not spin
Video power supply fan not spinning
If the power supply fan is not spinning, the possible cause of damage to power supply. Solution, replace the power supply.
How to check the damage to power supply
2. Power supply is weak (resulting voltage power supply can not turn on the computer or the voltage is less)
The characteristics of damage to the processor
Normal fan without processor
Normal fan with processor
Based on experience, the possibility of damage processors is very small. To check for damage to the processor, install the processor to another computer (for comparison).
The characteristics of main-board damage
Because the new main-board, so the possibility of the main-board damage, very small. The characteristics of damage to the main-board, when the power button is pressed
1. Power supply fan not spinning
2. Processor fan is not spinning
3. Casing lamp is not lit
4. Main-board lamp does not light
The characteristics of the memory damage or dirty memory
1. The characteristics of normal memory, but installation is not correct or dirty
When the computer is turned on, the sound
Solution
Picture a
Release Memory
Picture b
Clean the memory slots with a brush
Picture c
Clean the gold layer memory with a pencil eraser
Picture d
Reinstall the memory correctly
The characteristics of damage to video cards
Solution, remove the video card, clean the gold layer with a pencil eraser.
I hope this information helps.
Oct 23, 2011 | Computers & Internet
I have the red power light, but when i turn it on, it completely shuts off, red light and all. Then i have to unplug it from the back to get the red light back
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
NOTE.... you have to open the console to do this ...
I hope this help in solving the problem.....
Nov 10, 2010 | Nintendo Wii Console
MY PS3 WONT TURN BACK ON
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Lighting came into my computer via the ethernet cable. can this be fixed I also think it took out my power supply un it. It is a gateway 500c.
If only power supply's affected, then change the SMPS with a compatible one of the same rating. But first check the monitor by connecting to the mains power supply with the video chord not attached to anything. if the monitor displays "no videos" signal, then the monitor is OK cange the SMPS of the CPU and check UPS & spike boards fuses, otherwise commect to main power supply pluf(Wall 3-pin outlet socket)......sodeep
Jun 09, 2009 | Gateway (4000274) Motherboard
Panasonic TC-2119R 21" TV Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
