Question about APC BACK-UPS XS 1300VA LCD 120V (BX1300LCDX) UPS System
MASTER CONTROL OUTLET IS NOT WORKING - APC BACK-UPS XS 1300VA LCD 120V (BX1300LCDX) UPS System
  • 1,511 Answers
Hi and welcome to fixya there is a problem with the main power suply so you should not open or operate it anymore I strongly rec amend you to have an expert who can solve it manually
Posted on Dec 08, 2012
How to unlock my Rinnai Avenger 25TRE?
First turn the Master ON/OFF Switch to OFF. Ten unplug the heater from the electrical outlet. Wait 15 minutes, before plugging it back in. Then turn the Master ON/OFF Switch to ON and the heater should revert back to the factory settings. After that, you can set the controls as you wish.
Hope this helped you. Please let me know.
May 15, 2011 | Heating & Cooling
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Dehumidifer will not turn on. An E2 code comes up on the panel. Has been working fine for 4 day.
Since it has been working well for 4 days, it may be a case that the unit needs to reset itself. To accomplish this, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that timeout allowed the unit to reset itself. Also, check to make sure that the water collection bucket is installed properly and is making good contact with the safety switch.
Apr 27, 2011 | Haier 45-Pint Dehumidifier
Bulb blew in my dimplex michigan fire, model MCN20. I now can't get the bulbs to switch off with either the remote control or the on/off switch.
Stewart, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON and set the function controls manually (not with the remote) one at a time. If everything works as it should, the fire reset itself during the 12 - 15 minute timeout. If it didn't or that problem continues to reoccur, contact Dimplex North America, Technical Service at 888-346-7539.
Hope this helped you solve the problem.
Apr 27, 2011 | Heating & Cooling
How to reset a holmes humidifier
In most cases you can reset the unit by doing the following:
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set your controls as you normally do. If the unit has reset itself, it should now function properly.
Apr 06, 2011 | Heating & Cooling
All of the lights on the control panel are flashing simutanously and constant. The air cleaner is not working. I just had it tuned up about a month or so ago. Whats happening
Here's something that has worked in the past. Turn the Master ON/OFF switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes before plugging it back in. Once it's plugged back in turn the Master ON/OFF Switch to ON and set the controls as you normally do.I f everything now functions as it should, the unit reset itself.
If that doesn't solve the problem contact the Oreck Service Dept that did the tuneup for you.
Apr 04, 2011 | Oreck XL® Tower Air Purifier
I have an acer v229w and would like it to turn off when i power of my compu??
Just Google 'Green outlet strip power saver'
It is an outlet that you plug the PC into the 'Master' outlet, and you plug in your monitor, printer into the 'SLAVE' outlet. The Master outlet will sense the current draw (there is sensitivity adjustment) by the PC then it will turn on the Slave outlets, when PC is turned off, the slave will turn off also.
Apr 22, 2010 | Acer AL1916W 19" LCD Monitor
Does anyone know how to set up an old nintendo game
I am assuming you mean a nintendo entertainment system (NES)
You Need:
The gray master console
At least 1 controller
Power supply
RF Switchbox (Must be an auto switchbox) or an A/V Cable with RCA ends
The power supply & RF switch plug into the back of the grey master unit. Hook the RF switch up to the cable connection on your TV. (If using the A/V cable - it plugs into the side of the master unit & into a video in - yellow plug/audio in - white plug) Plug in the power supply. Make sure a controller is plugged into the 1 outlet on the front. Make sure a game cartridge is inserted & locked in (You push it down). The TV needs to be on whatever channel the switch is set on if using the RF switch (Channel 3 or 4). Turn on the power & it should work
Jan 03, 2010 | Nintendo DS Console
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug...
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Jun 22, 2008 | Fedders Heating & Cooling
Modular Home Wiring Schematics
Won't be a wiring schematic for it. If it is a modular it will be wired same as a house. Unfortunaltly it will be wired by the lowest paid electrician you have ever seen. LOL. If the wires are hot, put a multimeter on them and have someone flip the breakers one by one to identify the wires and breakers. If they are not causing any problems then they are just spare connections. Don't know why they would even be there.
Dec 11, 2007 | Computers & Internet
APC BACK-UPS XS 1300VA LCD 120V (BX1300LCDX) UPS System Logo
73 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
