Question about E-Machines eMachines Desktop PC
How to install power butto for et1161-03 - E-Machines eMachines Desktop PC
  • E-Machines Master
  • 5,660 Answers
Step 1:
Unplug from power. Remove all cables.
If you are not SURE where they all plug into, especially the audio cables; make a drawing, and notes before removing them.
Work ON a table, (Or workbench)
Open the computer case. Viewing the front of the computer; the Left Side Panel removes. There is a 'fingerpull' formed in the side.
Two thumb screws, pull the Side Panel back about 1 Inch; then remove straight out away from the computer tower.
Step 2:
FOLLOW Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static, BEFORE working inside your computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
Step 3:
The plastic front of your computer is the Front Panel.
Remove the Front Panel.
Look inside, and at the Front Panel, where it meets the metal frame of the computer case; towards you.
There are 3 tabs to depress, in order to remove the Front Panel.
They are plastic, and are formed out of the plastic Front Panel.
Over time, and heat; the Tabs are probably brittle. Use care as you depress/pull on them.
There is one tab towards the Top, one towards the Middle, and one towards the Bottom.
(If memory serves)
The ends of the Tabs have a hook. The tab must be gently pressed to the Inside of the computer, or gently pulled to the Outside of the computer; in order to move the hooked end towards the middle of the slot opening.
(There are rectangular slots in the metal framework of the compuyer case; that the Tabs go through)
Start with the Bottom tab. Once it's hooked end is clear of the edge of the slotted opening, (It will be in the middle of the opening), then gently pry out on the bottom of the Front Panel, JUST A LITTLE.
Now go to the Middle tab, then the Top tab.
Once the Tabs hooked ends are free, the Front panel should spin towards the other side, and come off.
Use care as there may be wires attached to the Power On switch/ Power On LED light, Harddrive activity LED light, etc.
It may, or may not just be a cover.
Believe it is set up like the eMachines ET1641,
http://www.ebay.com/itm/Emachines-ET1641-ET1160-ET1161-Front-Case-Faceplate-DVD-/170448123524?pt=US_Computer_Cases&hash=item27af7ff684
Looking at the far side, see the two Tabs? They look like the hooked end is to the Outside edge, which means they need to gently be pushed to the INSIDE of the computer.
Step 4:
Once the Front Panel is removed, there should be a Philips head screw, or more than one; that holds the plastic Power On button assembly, to the Front Panel.
Inside the plastic housing of the Power On Button assembly, is the Power On switch.
It may resemble this generic ATX power on switch,
http://www.directron.com/atxswitch.html
The plastic of the Power On Button assembly is probably hard, over time, and heat.
I use two different methods of removing the Power On switch;
1) The Power On switch is no good.
I use a bowl of water as hot as I can stand it; and place the Power On Button assembly down in it.
After a few minutes the plastic has softened.
Then G-E-N-T-L-Y pry the plastic tabs of the Power On Button assembly; so you can ease the Power On switch out.
2) I use a hair dryer. Constantly move the nozzle around, so you do not overheat just one spot. Plastic softened gently move the Tabs, and extract the Power On switch.
(You may need gloves. These old hands don't care anymore, lol!)
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Dec 16, 2012
How to turn on
press the power button. if your battery is empty, connect your charger. then press the power butto
Nov 28, 2013 | Acer Computers & Internet
My sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Check the back for speaker wire shorts, next! there may be a short in the audio output chip or surrounding parts in the stereo, this is more suited for a technician to sort out.
Jul 03, 2012 | Sony CMT-NEZ3 Shelf System
The power butto lihgt blinking bud no turn on
blinking light indicates that some thing is wrong inside the tv circuitary. may be any IC of any other component is short & not letting the power supply working. if you are a technical expert of tv you can cold test the power supplies for short circuit. or you can call a tv repair expert.
Oct 21, 2011 | JVC HD-61Z575 61" Rear Projection...
Installing remote starter what does run start posisition mean
When testing the polarity of the vehicle's main power wires for remote starter installation; the run position is the vehicle running. The ignition, accessory and battery wires should read 12 volts in the RUN position. This same group of wires should read 12 volts in the ON position. The ignition, starter and battery wires should read 12 volts in the START position. The accessory and battery wires should read 12 volts in the ACC position. The battery wire should read 12 volts with the key OFF.
Oct 18, 2010 | 2000RS-M Remote Starters Manual...
My toshiba tecra 8200 will not turn on when i hit the power butto tne green power light changes to a flashing yellow and stays that way
the power pack or the battery needs to be replaced
chrck the out put of the power pack with a volt meter to see if the output is fine
if so replace the battery
Radio Shack will test the power pack for you if you can not
Jun 27, 2010 | Toshiba Tecra 8200 Notebook
Kenmore HE2 dryer will not start
the relay for the motor is probable stuck recommend service
Jun 03, 2010 | Kenmore 82822 Electric Dryer
I need the manual for this unit. (I recently had
Click HERE to download user manual copy of Galaxy 2000RS
Hope this will help you.
Thanks.
Dec 12, 2009 | 2000RS-M Remote Starters Manual...
Bluetooth
There is no BT butto. You have to do it from the control panel.
Sep 20, 2009 | Computers & Internet
Repairing color television philips
Some tv's let you select menu from the buttons on the tv,on of the buttons will say menu and the volume and channel buttos will have a double function like an arrow to the right and left and arrow up and down,they also have a buttos that says select,press menu and use the others buttos to move thru the menus until you get to the color bar,if it is at minimum adjust it so you get your color back but if it is already in the middle the tv needs to be service.Philips sells universal remote controls that are already program to work your tv being a philips and you dont have to programe it and you can also access the menu.
Oct 02, 2006 | Abt Television ABT IJETABT01 WIRELESS RF...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
