Question about Aerobie Arrow CT50 Professional Cordless Staple Gun
My arrow CT50 is not shooting staples - Aerobie Arrow CT50 Professional Cordless Staple Gun
What.size staples needed for arrow fastener ct50
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Jan 11, 2018 | Arrow Tools & Hardware - Others
Why my arrow fastener ct50 wont staple
Open up the stapler and look for a jammed staple near the opening the staples c0ome out of, had this very same problem, just a few screws to open the gun up and a small screwdriver to pop the staple out.
Arrow CT50 stapler I am looking for a staple gun which I could use for upholstery, It would need to drive staples into extremely hard wood. Thanks
Sorry we do not have that information. I suggest you contact a local Auto Trim shop and ask them what they use.
May 17, 2017 | Arrow Tools & Hardware - Others
Will not shoot staples
i got a trutac arrow stap[le gun but it will not shoot staples out
Oct 26, 2013 | Arrow Fastener Staple. TruTac Forward...
New electric arrow stapler et501. Will shoot a staple but when you reposition to shoot a second wont always fire off. Sometimes can shoot 2 or 3 in a row and then then will not shoot. gun does not...
Check the instructions for cleaning and lubrication tips. Sounds like you have a buildup of the adhesive that holds staples in "sticks," and it's keeping the staple stick from moving forward into the firing position.
Oct 16, 2017 | Heavy Duty Arrow Et501 Electric...
I have the Arrow CT50 stapler, it won't drive the staple, light works makes a sound like it wants to drive staple but don't. I have adjusted the power to all the way + and the battery shows 4 green lights....
It sounds like the battery is failing low battery voltage equals loss of power. The batteries used in this type of tool are the cheapest ones out there to keep the cost of the tool low, and have a very short lifespan, it is not the number of times used but how old they are that is the main factor
Feb 28, 2011 | Arrow Ct50k Professional Cordless Staple...
My t 50 does not shoot staples although chamber is loaded
Hi, Dayne here
Well, it might sound too easy, but did you check for jambed staples. I also lightly oil all mine. Sometimes the actual plunger that drives the staple will break internally.
Thanks
Dec 12, 2010 | Arrow T50P ARROW STAPLE GUN
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
Staples will not shoot flat. Have to hammer them
well most home hardware ones all do that if used on anything hard/heavy timber.....if it is a heavy industrial one it may need anew spring.
Jul 22, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
Aerobie Arrow CT50 Professional Cordless Staple Gun Logo
65 people viewed this question
Top Aerobie Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Aerobie Tool and Hardware - Other Expert? Answer questions, earn points and help others
