Question about Brother IntelliFAX 1270E Plain Paper Fax
I need to change setting for a ring mate mode but don't know how
I just changed phone services and now have my fax number as a ring mate line, i now need to change it in the fax and can't find the manual to do so. Please help!
    Novelist:
  • Brother Expert
  • 297 Answers
Link to manual is here:
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
You need to follow instructions on page 20, i think !
Posted on Jan 22, 2009
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Change number of rings to answer on iRC3170 fax
I believe, you just have to open the doors on the control pannel. It will show you more funcation of the fax. There should be a botton that say's "Data Entery" press it once and the display changes. Next you use the arrow bottons on the control pannel to move in that mode. Scroll down to Fax Setting and press the OK botton and scroll some more till you see number of rings and change it from 5 to 2 rings. Then press OK or Set, the press Stop/Rest twice and you should be done. It's alot hard to explain then doing it. It's called panich botton pushing..... Good luck
Jan 01, 2009 | Office Equipment & Supplies
Fax answer phone line
You set the machine up in the answer/fax mode, when a fax is coming in you have to press 9 on the phone to make it receive the fax if you pick up the receiver when it is a fax call.
You can also change the number of rings to answer a fax, I think the max is 7 rings.
Dec 20, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax pick up
Greetings Nana,
I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother IntelliFAX 1270E Plain Paper Fax Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
