Question about Cisco Catalyst 3750V2 24 10 / 100 PoE + 2 SFP Standard Router
Voice configuration on catalyst 3750V2
Can a Catalyst 3750V2 switch route local calls on a network without any external device or software
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 143 Answers
The short answer: No
The long answer: You will need a device that will handle call control. That can be an ISR router (gen2 example: Cisco 1900, 2900, or 3900 series) that runs Call Manager Express, or a Cisco UC5XX Box (or even full blown CUCM, though you will still need an ISR to get out to the PSTN). The switch will work great for the infrastructure side of things though. It is capable of layer 3 routing, voice VLANs, QoS, and PoE. But you WILL need something for call control.
Posted on Apr 16, 2014
2 Suggested Answers
domotek
  • 591 Answers
SOURCE: Hi ... We have a problem
pleas give the (show TECH and show RUN) command output to me i could help you... I know this is a serious security issue but EDIT the output TXT file to change the compromising info to some other fictive info. before POSTING it on this site....
carefully check the 3560 VLAN rooting rules there might be a conflicting deny or allow rule remember deny circumvents allow ruels...
thanks!
Posted on Feb 18, 2011
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Cisco Catalyst 2960-S VS 2960-X Series Switches?
2960-X is manual configurable and 2960-S is smart dont need to configure.
Apr 10, 2014 | Computers & Internet
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Catalyst ws-c2926 password recovery problem
  1. Attach a terminal or PC with terminal emulation to the console port of the switch. Use the following terminal settings:
    9600 baud rate
    No parity
    8 data bits
    No stop bit
  2. Unplug the power cable.
  3. Hold down the mode button while reconnecting the power cord to the switch. You can release the mode button a second or two after the LED above port 1x is no longer illuminated.
    The following instructions appear:
    The system has been interrupted prior to initializing the flash file system.
    The following commands will initialize the flash file system, and finish loading
    the operating system software:
    flash_init
    load_helper
    boot
  4. Type flash_init.
  5. Type load_helper.
  6. Type dir flash:. The switch file system is displayed:
    Directory of flash:
    2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
    4 drwx 3776 Mar 01 1993 01:23:24 html
    66 -rwx 130 Jan 01 1970 00:01:19 env_vars
    68 -rwx 1296 Mar 01 1993 06:55:51 config.text
    1728000 bytes total (456704 bytes free)
  7. Type rename flash:config.text flash:config.old to rename the configuration file. This file contains the password definition.
  8. Type boot to boot the system.
  9. Enter N at the prompt to start the Setup program, Continue with the configuration dialog? [yes/no] : N
  10. At the switch prompt type en to turn on enable mode.
  11. Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
  12. Copy the configuration file into memory: Switch# copy flash:config.text system:running-config
    Source filename [config.text]? (press Return)
    Destination filename [running-config]? (press Return)
    The configuration file is now reloaded.
  13. Change the password: switch#configure terminal
    switch(config)#enable password Cisco
    switch#control/Z
  14. Write the running configuration to the configuration file:
    switch(config)#write memory
Jun 07, 2008 | Cisco Catalyst 2926 (WS-C2926) Networking...
Network
Follow these steps
example
int serial0
ip address 192.168.1.1 255.255.255.252 ( give 1.2 to other end)
ip address 192.168.2.1 255.255.255.252 secondary ( give 2.2. to other end)
ip load-sharing per-packet
ip route destination network destination mask 192.168.1.2
ip route destination network destination mask 192.168.2.2
GOOD LUCK
Jan 07, 2008 | Cisco Catalyst 2950 24x10/100 Mbps...
Hardware Problem
Probably a bad power supply. Is it getting through power on self test? Any LEDs illuminated when you power it on? Best way is to first connect a terminal configured at 9600,N,8,1 to the console port and then power it on. If you see it running through self test in a few (10-30) seconds, then it's starting up, watch the screen for any errors. If not, then your power supply is probably shot.
Nov 14, 2007 | Cisco Catalyst 3560-24PS Switch
Cisco Catalyst 3750V2 24 10 / 100 PoE + 2 SFP Standard Router Logo
87 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
