Question about Sony STR-D565 Receiver
I would like to buy a record player to my sony receiver model str d565 - which record player goes with the receiver?
4 Suggested Answers
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
Why is it blinking protect?
Try disconnecting all the speakers and turn it on if it still goes into protect you will need to get it serviced but if it turns on then you have a problem with the speaker or wire run (check for shorts )
Roger
Jan 07, 2016 | Sony Str-d565 Digital Audio Video Control...
Protect mode
I didn't see any mention of it in the STR-D565 manual, but on many other Sony models the "Protect" indicates a short in a speaker wire.
Aug 22, 2013 | Sony STR-D565 Receiver
I have rewired my receiver and the SOny str-d565 keeps shutting off. Is this fixable or should I just get a new receiver?
This unit most likely has shorted output transistors. The unit is entering protect mode which will prevent further damage to the unit. Expect a parts cost in the $40 range for this repair.
Dan
Feb 11, 2011 | Sony STR-D565 Receiver
I still have a Sony STR-D565 Receiver - but there's one major problem. After a variabel time in use it stop working. If I push the ON / OFF button , It gives the receiver new life, but just for a while....
If the word "Protection" is not flash in the display when this happens, then the receiver is in a tight area where it can't get enough air and is over heating. There are temp senosors on the heat sinks where the output transistors are mounted, and they will shut down the power supply in an overheat situartion, but the protecting indicator shold flash. Blow some air over the receiver and see if that stops the problem.
Aug 30, 2010 | Sony STR-D565 Receiver
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
Apr 04, 2009 | Sony STR-D565 Receiver
Operating instructions for sony str-d565 receiver
Feb 23, 2009 | Sony STR-D565 Receiver
MODEL STR-D565 PROTECT LIGHT FLASHING
Hello!
Your amps' output section is shorted and is sending it's supply voltage straight to the speakers. The protect circuit is there to protect your speakers from being burnt. You need to go to an authorized Sony service center. Good Luck!
barneyluc
Oct 11, 2008 | Sony Audio Players & Recorders
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
