Question about Refrigerators
I have a ken more refrigerator the foot broke on it do you know where I can get one?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 08, 2012
I need to know the cubic feet of my Admiral refrigerator model #CNS22V8 serial #KT39003573 Thank you
The details are not available online. Measure it yourself. Measure (in feet to nearest 3") width and multiply by depth, and then multiply that by the height.
1 foot 3" is 1.25
1 Foot 6" is 1.5
1 Foot 9" is 1.75
1.75 x 1.5 x 4 is 10.5 cu ft
May 15, 2016 | Admiral Refrigerators
PART THAT SUPPORTS THE ICEMAKER BROKE OFF AND I NEED A REPLACEMENT. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
ICEMAKER BROKE AND I NEED A NEW ICE MAKER. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
Jul 07, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking freon
Repairing sealed system GE side by side
Sep 23, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
The unit get too cold and freezes all the refrigerator food items
HI. I know you tried to turn it down.. The only thing left. is the temp. control is bad and the unit runs all the time. need to replace it.
Hope THIS HELPS Ken
Sep 22, 2009 | GE Refrigerators
The dial in the Fridge has settings from 0-7. which is the number to get it colder, it is currently on 4 and the freezer is not freezing
The higher the number the colder it gets. But I think your problem might be something like dirty coils under the frig or the fan inside the freezer is not working. Let me know more info. ken
Jul 02, 2009 | Liebherr European Right Hinge Fully...
How do you evac and recharge a true freezer compressor??
Your unit takes R-134A you can buy that anywhere it is 0 depletion on Ozone. The hard part is getting access to your lines if you have a service tap installed piece of cake. They make a saddle valve you can install to access line set. Pull a vacuum on unit takes a vacuum pump and about one hour of running the vacuum. Just put one line tap on the line and be sure it goes on the low pressure line not the high pressure side. The unit the fridge only takes about 5 ounces of refrigerant and has to be weighed in. Also has to be put in as a liquid as this is a blend of refrigerants. As long as you have gauges and pump and a scale I can walk you through it step by step get back with me and we can do that. ken
Jan 11, 2009 | True GDM-41 Refrigerator
The light bulb in top of refrigerator broke, can't get it unscrewed using potato method. also tried to bend the base with a screwdriver then turn using needlenose pliers. It won't budge. What else can I...
This is where you are going to have to get ruff. Be sure the refigerator is UNPLUGGED. Grab one side of the base of the bulb with your pliers and rotate counter clockwise. Only way to get it out. Short of taking the whole light bulb assy out of the unit. More then likely got a little rust on the base of bulb and just enough to make it stick. Once it breaks loose you are home free. ken
Jan 03, 2009 | Refrigerators
Freezer coils keep freezing up
Start by opening the freezer door and listen for a fan blowing. As long as the compressor is running the inside fan should be running. If it is running go to next item. If it isn't running that is the problem. Need to replace the inside fan.
Next step locate the defrost timer usually in the same housing that the thermostat is. Now look for a screw driver recessed area that would allow a flat screw driver to turn or advance the timer. It only turns one way so be carefull. Advance the timer till you hear a click that should be defrost. Now wait approx. 30 minutes and see if the timer has advanced on it's own. Should be out of defrost and back in cooling cycle. let me know what you find out on these two solutions. ken
Dec 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Need to take panel off to clean coils
Okay it is just held on by two small squeeze type clamps. Take a little flashlight and locate the clamps. Either lift and remove or pry off very gently only way to see is looking at it from ground level. ken
Dec 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
