Question about Kitchen Ranges
I have Kenmore Elite smoothtop range that was part of the recall a few years back. Now the oven seems to turn itself off or heat to different temperatures and it beeps ALL THE TIME for hours after using it. No error codes show up. The range is 9 years old (I would have expected a bit more time out of it) and I am not sure if it is worth fixing. Any suggestions?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 08, 2012
SOURCE: No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Posted on Oct 06, 2007
SOURCE: GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
Posted on Jul 21, 2008
  • 272 Answers
SOURCE: Error code E2 F2
As you are aware the technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
E2 relates to an overheating condition. Quite possibly related to your touchpad issue. I'd try cleaning the contacts and if that doesn't work...Up to you at that point!
Good luck
Posted on Jun 01, 2009
SOURCE: Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Posted on Oct 25, 2009
marka19
  • 1430 Answers
SOURCE: Oven lights ,but doesn't heat to preset temperature
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 17, 2010
Testimonial: "Exact problem and solution, Thanks"
Kenmore c970-440935. Why does one element overheat?
Kenmore Elite C970 440935 Replace heating element range
www.fixya.com > ... > Ovens > Kenmore > Kenmore Elite C970 440935
Kenmore Elite C970 440935, replace heating element range related issues. Get free help, solutions & advice from top Kenmore experts. ... Kenmore 40494 / 40495 / 40499 Electric Single Oven. 793 Questions ..
Aug 05, 2015 | Kitchen Ranges
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Kenmore Elite Electric Rnage 2 years old model 790.9662. If you set oven to 350...never gets there or takes forever. I gave up after 35 minutes abd it was only at 235. HELP! PLEASE!
the gas valve on the back isnt on... the valve doesnt stop the stovetop from working, only the oven. You are seeing the ignition element heating up and thats slowing heating the oven.
Jan 11, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My kenmore electric smoothtop range's oven doesn't work. Broiler and burners are fine. Any help?
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | Kenmore 96532 / 96534 / 96539 Electric...
Top Oven shutdown
If I did get it fixed, do you think I would tell you. Your sight is very misleading. It says nothing about having to "subscribe" for a solution and besides, I never actually sent send when I filled out the boxes and the next thing I know is you were asking for a payment. Sounds a lot like fraud to me.
Dec 09, 2009 | Kenmore Kitchen Ranges
My PLEFMZ99GC is showing an
Please read this article... it appears our model is under recall by Fridgidaire. You should probably contact the manufacturer right away to see what should be done...
http://www.appliance.net/2009/recallfrigidaire-and-kenmore-smoothtop-electric-ranges-due-to-fire-hazard-1369
Oct 25, 2009 | Frigidaire PLEFMZ99GC Electric Range
I have a 2 year old smoothtop GE stove. I was
that clicking usually means that the erc is trying to turn on the burners,
i would unplug the range
pull it out and check all the connections of the bake element
Oct 16, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Small oven on double oven Kenmore range quit working
Sounds like the sensor switch needs to be replaced.
May 17, 2009 | Singer 3116 Simple
Problem with a different range...
Tom, generally a f1 code implies a control problem. The tech sheet gives 3 possible causes. 1. A shorted keypad, solution to replace electronic control. 2. Controls internal checksum has become corrupt, solution is to unplug for 30 seconds, if the code comes back, replace the electronic control. 3. Control has sensed a overheating condition, relay on the board may have shorted out. Each one recommends replacing the control board. The part I have for this model number is 316127903. Says it's grey. Catriver..post back.
Oct 24, 2006 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
