My goclever tab r74 wont charge
Tried all charging methods eg. usb and charger but it just flashes when trying to charge
ambrose313
  • 85 Answers
SOURCE: charging zen v plus
Yes you need a creative charger. generic brands usually damage any electronic device. you need to get a creative charger, and hope that it will solve your problem. if not then you may need to ger a battery too. connie
Posted on Jun 22, 2007
SOURCE: Iriver PMP-120 will not turn on
i wos camping when my pmp 120 stoped workin so i smashd it up there and then that seemd to work lol
Posted on Jul 22, 2007
SOURCE: oakley thump pro glasses wont charge
Check to make sure you are using the USB cable that came with them. Although other cables plug in they create the problem you have. I have had a similar experience.
Posted on Jul 20, 2008
SOURCE: My Sansa Fuze Wont Turn On or Charge
Hold down the power button for 30 secconds to a minute, then let go and turn it on again as per normal. This is a built-in reset function.
It seems to happen for me when certain mp3's are played, i think they might be corrupt and the palyer doesnt like them, and so crashes.
Hope this helps!
-DaALC
Posted on Jul 19, 2009
  • 699 Answers
SOURCE: problem charging my gpx ml759b
The GPX ML759B has a Lion-Polymer rechargeable battery which does wear out pretty quickly especially when playing MP4 Videos. If your unit is 18months, you have done well!
If you have tried charging charging your player in a couple manners as stated, and you are happy that the charging system is working, then I strongly suspect that you will need to replace the internal LiOn-Polymer battery (whcih usually have a max life of 500 charges).
If you cannot replace the internal battery yourself, you may find that it may not be an economical option for a relatively cheap MP4 player.
Posted on Dec 20, 2009
Lenova tab s8 wont charge help
Hi, it maybe possibly your battery to drained flattened to the point where it cannot accept a charge from the wall charger. the best thing to do is to try and trickle charge your tablet from a low voltage/amperage connection. Either a powered on PC USB port to the charging connector on your tablet, or from a low power phone charger (5v/500ma). It has been pretty well documented that lithium batteries do not like to be drained fully & it may be that the battery in your tablet has drained so low that it cannot accept a charge from the Lenovo a/c charger.
Try a trickle charge for 8-10 hours (or longer) on your tablet & see if that gets enough charge into your battery to enable it to recognise & accept a charge from the a/c charger.
Else it replacement of charger or some hardware failure in your tablet
Oct 04, 2015 | Computers & Internet
My tab wont turn on
Basically, if you have to try and establish "IF" the charging system is at fault or yor Tab 2 device by substitution method.
By substitution method I mean try your charging accessory(s) on a friends working Tab 2 or product that uses same cable connection and or theirs on yours.
I can't quite fathom two of them can have same problem i.e.Tab 2 devices BUT can understand if you ONLY tried 2 different cables and NOT the USB power supply that regulates the electricity, meaning I doubt you're refering to TWO Tab 2's being faulty, but rather charging system made up of plug pack with USB connector and USB cable to Samsung Port connector.
Good luck.
Jan 18, 2015 | Samsung Galaxy Tab 2 7.0
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Go clever terra 90 authentication problem cannot connect to the internet through wi-fi
Since internet passwords are case sensitive you need to verify that the "Caps Lock" is not on or verify correct case for password.
Feb 08, 2014 | jianting Li White Folio Leather Case For...
My samsung tab 2 wont charge. what can i do?
Perhaps you try this question in the category Tablets, hardware or Android devices?
This question became between camera flashes, you know the things that give a bright light for a short time, when a picture is made.
Nov 13, 2013 | Samsung Galaxy Tab 2 10.1 16GB 3G Wifi...
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Samsung galaxy tab will not charge via car charger with a usb charging method. The device says turn on mass storage. I have done that and it will still not charge. It will however charge when the device...
For most android platform products when you have "Mass Storage" turned on it wont charge. Its possible that the Car-USB charger isn't putting out enough juice to charge it in its on state. Could be to the quality of the car charger or that the car is already under strain from say a stereo or other devices being charged.
May 04, 2011 | Samsung Cell Phones
Iv tried to charge my 24v battery but the charger is flashing very quickly and its not charging the battery
Either indicates the battery is bad or that the temperature is too hi or low to charge. Let battery reach room temp apart from the charger then try charging again.
Feb 27, 2010 | Saws
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
340 people viewed this question
 Grubhead
Grubhead
