Question about Dell U2410 24 inch Monitor
Fuse dell 2410
Monitor ceased to function when I plugged it into my Apple laptop. I believe there is a theory that sometimes connecting a Display Port blows the fuse. I am trying to crack it open so I can check this theory. I have successfully operated on other Dell monitors by lifting the top left edge of the bezel, but the 2410 bezel is not letting go and I don't want to damage it unnecessarily. So - question is - how do I open it up so I can check the fuse?
3 Suggested Answers
SOURCE: dell monitor 828fI NEEDS A FUSE ON BOARD H 250V T3 15A
Go to the hardware store.. There are a lot of it.
Posted on Feb 27, 2009
  • 3940 Answers
SOURCE: Dell monitor attached to Inspiron 1520 runs landscape (sideways)
try CNTL+ALT+Up arrow/Down Arrow
Posted on Apr 14, 2009
My Dell E173fp monitor display doesn't work with my macbook
The fine print says it should work. Real life might be different. Do you have a genius bar, found at Apple stores, anywhere close? If so, make an appointment and let them make the connection for you. The genius bar is a free service and I've never found anything that they haven't been able to fix...and fix it quickly...if it's fixable.
Apr 17, 2017 | Dell E173FP 17" LCD Monitor
No signal input wen connected to the VGA port of my Dell M1210 (Win 7). using an VGA to DVI cable. If i connect the CG223 to an old laptop (vga) it works fine.
The Dell M1210 hos only a VGA output or s-video output, both being analog. If you are connecting the M1210 VGA to the DVI input on the monitor then this will not work. You need to connect to the VGA input on the monitor.
May 25, 2011 | Eizo CG223WBK Monitor
Hi, My Dell Studio 1735 Laptop doesnot display anything, i hear sounds of it getting rebooted and startedup but, wont display anything. I tried conencting to external monitor NO...
The video card most likely has failed. The computer will need to be serviced by a trained technician. The entire motherboard will need to be replaced.
Feb 28, 2011 | Dell STUDIO 1735 Motherboard - H274K
Hello, i can't connect my projector to dell n5010 laptop. no device find when connect projector to laptop. please help me.
The following is from page 69 of the 354-page Dell Technology Guide for the N5010
General Keyboard Shortcuts
<Fn><F8>
Displays icons representing all currently available display options (display only, external monitor or projector only, both display and projector, and so on). Highlight the desired icon to switch the display to that option
So the solution is just plug the VGA cable from the projector into the N5010 laptop's VGA port and then press <Fn><F8> (Function and F8 keys together).
Feb 13, 2011 | Computers & Internet
Hi, I have a Dell Latitude D830. The display was off. I can connect extrenal monitor for current work. Please advise if I need replace display or motherboard ? Thanks Alex
Before replacing anything verify that your laptops display type didn't get changed to VGA out only.
look at your function keys (usually top one or two rows ) and look for the key that has a pc/monitor icon. with the machine powered up and connected to the external monitor press the function (FN button lower left of keyboard) and the video/monitor button at the same time. most laptops have 3 settings:
laptop display only, external display only and laptop and external display. Press the FN/Display button at lease 3 times waiting 3-5 seconds between keystrokes. I have seen this many times where the FN/display button keys are hit inadvertently.
Typically if the motherboard or video card fail the external monitor would not work either.
Jan 04, 2011 | Dell Latitude D830 Notebook
My Del Latitude C400 screen will not work how do i plug in an external monitor
connect to external monitor with 15pin connector. and there is one function key is there with symbol of monitor. at the time of booting presss that key external display will come
Jun 16, 2010 | Dell Latitude C400 Notebook
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
How do I connect my apple model m7649 monitor to a dell laptop? Thanks to anyone, ron
you should be able to get hold of a convert that plugs in to your laptop then you should be able to plug the monitor in to the converter with out having any problems with display settings
hope the information is abit of help to you
Mar 04, 2009 | IBM (14R0060) Monitor
Monitor no longer working after latop connection
Assuming that you are using Windows Vista, and the monitor is plugged in and connected correctly (with power on!), right click on your desktop, and select Personalise, and then Display Settings. You will see the second monitor greyed out. Right click on the greyed out monitor and select "Attached". Click Apply. The monitor should now be activated.
Sometimes, there are specific graphics card programs loaded on laptops, such as NVIDIA etc.. which may also control the settings.
Dec 09, 2008 | Dell Vostro 1500 Notebook
Display black cant see well or at all.
i'm afraid that's right, your laptop display is malfunctioning
Nov 29, 2008 | Computers & Internet
Dell U2410 24 inch Monitor Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
