Question about Technics SL-MC6 CD Player
My technics SLMC6 has a message running saying 'checking discs' and it will not do anything else.
  • 1 more comment
  • dale daniels Dec 08, 2012
    Yes, thank you for suggesting this. I called my local electronics repair shop that has been here for years. $49.00 plus tax to repair. Well worth it! Thank you again, Tom. dd.
  • dale daniels Dec 17, 2012
    Tom, Turned out to be the laser. Discoed part. Thanks again.
    Tom, Turned out to be the laser. Discoed parts. Thanks again.
    Top Expert:
  • Technics Master
  • 44,044 Answers
Drive mechanism failure. My Technics unit had a similar problem which turned out to be drive belt failure.
Posted on Dec 07, 2012
  • 1 more comment
  • dale daniels Dec 07, 2012
    Thank you so very much, Tom. Had an idea that it might be serious. I appreciate the quick reply! dd.
  • Tom Chichester Dec 08, 2012
    Probably can be fixed but requires disassembly
    Thank you, Tom. I checked with my local electronics shop and it's 49.00. Well worth it!
Tip
Facebook-Sorry we are experiencing temporary technical problems
<span>Sorry, we are experiencing temporary technical problem, please check back later</span><br /><span><span><br />If you are trying to use Facebook or a certain feature on Facebook and receive this error message, don't worry. <br /><br />This message usually means they are working on some technical issue and everything will return to normal after they fix it. <br /><br />Unfortunately, there is no way to say how long this will take. Your only option would be to contact facebook customer support to see if they can provide any further details. You can do this directly on the facebook website by clicking Account then Help.<br /><br />-G33k<br /><br /><br /><br /><br /><span>keywords</span><br style="font-weight: bold;" /></span></span><span style="font-weight: bold;">Sorry, we are experiencing temporary technical problem, please check back later, facebook technical problem, facebook error message, can't use facebook, facebook not working</span><br /><span><span><br /></span></span>
on Jul 24, 2011 | Facebook Social Network
I have a T85 Treadmill and the running platform is stuck in the highest position. A message on the display says 'check Transmitter'. Is there anything I can do to fix it?
PLeae RUN the software calibration for troubleshooting go under the HOOD motor and read the instruction steps, or go to instr. manual in how to enter in the s.calibration and fix it.
However you can measure the input voltage elevation motor, and lube the shafte, gear, see the photo and diagram attached.
God bless you
Nov 18, 2012 | Tunturi T85 Treadmill
TECHNICS SL HD81 5 CD MULTICHANGER. The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on th
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
Nov 04, 2012 | Technics Audio Players & Recorders
Slp111 cd door sticking
Hello
You are talking about loading motor and its connecting belt. Check whether the loding motor has pulling power to eject the disc tray out. This is a common complaint with most models of CD players. Just replace the loading motor and loading belt.
Mar 01, 2012 | Technics Audio Players & Recorders
Dell dvd bad CD OK
please check what type of dive it is cdrw/dvdr or only COD -rom...if only cd rom it will not read DVD's...go to run ...then type msinfo32 then components finally under check the type of CD/DVD drive installed...if everything is ok...reinstall the chipset drivers....thanks...also if u can check in BIOS if the drive is getting detected.
Feb 13, 2012 | Computers & Internet
I cant run or play and copy anything on my pc says error
Check if you have no disc space left ?
Check the CPU usage in your task manager? You can see which process is consuming most CPU cycles. Try to kill that particular process through the same task manager and then try running your application.
Jan 17, 2012 | Computers & Internet
I own a technics CD changer Model SL-PD 787. The system powers up showing the disc & track no. but the timer does not count down . and therefore does not play. How can I fix the problem.
Actually it's the other way around. Playback makes the counter move. Did you hit PLAY or try to seek to a track or anything to verify it 'likes' the disc?
Sep 22, 2011 | Technics Audio Players & Recorders
Unreadable Disc says reading and then open tray
The easiest and most permanent fix would be to install a new drive. The process is simple and does not require alot of technical skill. Get your unit back up and running good for like fifty dollars or so.
May 30, 2009 | Microsoft Xbox 360 Console
Was recording fine then message to check disc when turned back on
Unless you've been unlucky and had two bad discs in a row its probably the camera. have you tried resetting the camera and trying again?
Jul 13, 2008 | Panasonic VDR-D100 DVD Camcorder
Technics SL-MC6 CD Player Logo
320 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
