Question about Radio Communications
Cobra ga-cm .THE CHARGER (DUAL) RECEPTACLE WHERE THE PLUG RUNS FROM THE WALL AND PLUGS INTO THE CHARGER IS BROKEN ACTUALLY MISSING OR DEMOLISHED WOULD BE CLOSER TO THE TRUTH. I WOULD LIKE TO CLIP (OFF) THE BARREL CONNECTOR AND SOLDER THE WIRES DIRECT TO THE BOARD OF THE CHARGER... THANKL YOU FOR ANY HELP YOU MAY OFFER
5 Suggested Answers
vrc_tech
  • 109 Answers
SOURCE: Charger / Adapter
Radio shack sales a universal power adapter. <CAUTION> make sure the adapter is set to the correct voltage and that the tip is set to the correct polarity. The only other option is to order the adapter from Cobra.
Pat
Posted on Aug 21, 2008
  • 40 Answers
SOURCE: I need an electrical connection for 2-way Radio charger base.
Check the voltage of the battery and pick something 1-3 volts higher.
If you have an ohm meter you can meter between battery contacts and charger wall wart jack and see which one is positive and negative and match your transformer up to it.
Posted on Jan 23, 2009
SOURCE: broken ac outlet from board. where do i get parts?
found a part at a local store and soldered it to the board.
Posted on Jun 06, 2009
  • 2069 Answers
SOURCE: I have a Kenwood TH-78A.
please get all the instructions on how to fix your antenna here.
I hope that helps and thanks for using Fixya!
Posted on Aug 09, 2011
I have the Auvio Bluetooth speaker n can't find the charger..where can I order another charger for speaker at??
On the rear of the speaker, you should see a female receptacle, probably the same as your phone. the other end is a usb which would plug into the computer to charge or you can pick up a 5volt wall charger that the usb cable plugs into and the charger plugs into the wall. Any walmart, fry's, radio shack has the readily available.
Jun 02, 2017 | The Audio Players & Recorders
What (low voltage) goes from wall plug into (charger stand)? Thanks, Richard
I don't know what the question is here for sure but the voltage is converted to 12 volt from the wall to the charger. Milliamps is the only variation from charger to charger.
Jan 22, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
What volt charger is needed for (cobra microtalk pr560wx)? Thanks,Richard
Hi Richard,
Volt Charger??? I'm not sure what you mean, but if you mean what voltage to recharge the batteries, then you need to look at the unit, all over to find the AC input, there should be something tht states voltage and polarity there, if it infact has one.
Pease reply with more detail re: your query.
Regards,
Peter
Jan 20, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
I do not have an owners manual for my Dalton power wheelchair. When hooking up the charger do I plug in the charger and then the chair or vice versa? And should the chair be turned on when its charging?...
You should plug the charger into the chair first, then into the wall receptacle. The chair should be turned OFF when charging. This will allow it to charge faster and completely. When charging is complete, remove the plug from the wall receptacle first, then from the chair.
Feb 26, 2011 | Health & Beauty
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Plug is broken
You can buy a new Durabrand Dual car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand Dual 7b portable dvd player
You can buy a new Durabrand Dual wall ac adapter by clicking on the hyperlink:
buy replacement wall ac adapter power charger cord for DURABRAND Dual 7b PORTABLE DVD PLAYER
Jun 20, 2009 | Durabrand Portable DVD
Jan 16, 2009 | Cobra 2 mile FRS 2 pack Value Pack with...
Charger / Adapter
Pat
Aug 05, 2008 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Radio Communications Logo
35 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
