Question about Garden
1862 cub cadet how to replace starter - Garden
  • 7 Answers
SOURCE: replace starter motor in a cub cadet
What model do you have.
If its a twin cylinder kohler,you will have to lift the motor
Posted on Sep 05, 2008
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
Cub Cadet 1862 starts when I pour gas into the carbeurator but won't keep running, fuel filter is ok. Any Ideas? Thanks, Russ
Russ. it isn't getting fuel for some reason. if it has a fuel pump unhook it at the carburetor and see if it pumps fuel. if it don't replace it. if it does take the carburetor off and clean it real good with carburetor cleaner. be sure gas flows to the fuel pump when you take off the line. it could be a plugged fuel filter.maybe put a new kit in it. they are cheap. you have water or debris somewhere. it is just a process to find where it is.
Feb 21, 2017 | Cub Cadet Garden
Where is the fuse on a 1046 Cub cadet?
behind the dash right side try to jump starter if catch then try then go to starter silinoid jump it will try to start if doesnst replace it if dose work go to switch relay beehind dash near fuse let me no what happen
Sep 01, 2014 | Cub Cadet Garden
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
