Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Motor hums but door will not open or close.
I have a 1/2 HP Craftman Part #41A4315-7A (5-94) HBQ0777, garage door opener. I am told by Sears that this is an old opener and no longer available. I would like to know what would be compatable with this motor so I don't have to replace the whole thing. There are two big springs that are pulled by cable on either side of the door and one chain in the middle of the door.
  • Anonymous Jan 23, 2009
    I have the same problem, and when I removed the cover the gears where turned into a big pile of powder = no Gears left!
  • 30 Answers
Well Good thing is that sears openers have not changed much int eh way they are hooked up. If you have a chain drive you can pretty much buy and chain drive sears opener and it should bolt right up. But you might have to run safety sensors as of 1993 they have to be on all openers. Also if you are going to do a motor head change out make sure your chain and door are in the closed position. All openers will start up once they are plugged in
Posted on Feb 10, 2009
  • 15,935 Answers
Have you increased the WORK setting on the unit? springs get weaker over time, and the opener must be adjusted.
Look on the rear of the unit for an adjustment knob labeled WORK or FORCE.
Increase the setting, and re-try.
Posted on Jan 12, 2009
New Sears craftman 1/2 horsepower garage door opener not staying closed, trolley is hitting bolt stop and auto reversing.Have tried to adjust the down force and the distasnce down setting to no avail?
The 'down limit' on the side of the motor housing is what needs to be adjusted. Turn this control in the opposite direction of the arrow printed on the cover. I usually adjust this so it stops short by quite a bit and then fine tune it.
Oct 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Sears Craftman Garage door opener model # 41a3493-1. Does it have auto reverse?
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Dec 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman Garage Door Opener Quit Working.
It could be a bad logic board especially if you have had any electrical storms in the area. I would remove and check the logic board for burnt or missing traces on the printed circuit board.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open or close
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
Mar 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
390 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
