Question about HP OfficeJet G85 All-In-One InkJet Printer
G85 remove the CMOS battery - HP OfficeJet G85 All-In-One InkJet Printer
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
HP 2230s is looking for a BIOS password. I have flashed the battery and no joy. Any suggestions would be greatly appreciated.
can you remove the cmos battery? some batteries are soldered in making it hery hard to remove
remove the cmos battery for 15 - 30 minutes this will remove your password and cmos settings
if you are working on a laptop on the underside of your laptop you will see removable plates use a phillips head or a flat head screwdriver to remove the plastic plate then remove the cmos battery it could differ on size might be the size of 10 or 20c piece
http://www.pchub.com/uph/category/307/Battery---Cmos-Cover.html
hope this helps you
Aug 13, 2011 | Computers & Internet
Got message "CMOS battery low" What steps are
Assuming you know how to get into your computer and identify the CMOS battery, you just need a pair of tweezers or similar to remove the battery. Once it has removed, take it into a drug store or pharmacy and find the exact same battery, and replace it in the motherboard. If you can't identify the CMOS battery, please let me know and I can help you with that.
Jul 19, 2011 | Computers & Internet
Vista driver for hp g85
Uninstall current driver (if any) before installing the new software from HP support: (choose your OS)
HP OfficeJet G85 Downloads
Jan 08, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
I have a satellite A105 and When i turn it on it asks for password but I don't have the password. So how to I get past this to be able to use it again?
just remove the cmos battery
the bios stores the password and the cmos battery provides it power to store it
if you remove cmos battery the bios reverts to factory settings and the password is removed
cmos battery is different than the laptop backup battery
cmos battery is found inside the laptop case on the motherboard, you will have to open the laptop to remove the cmos battery
Sep 29, 2009 | Toshiba Satellite A105 Notebook
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
May 04, 2009 | HP OmniBook 500 Notebook
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
Feb 28, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Please, describe all steps to re-install driver software for hp/g85 printer, after I use g85 self removal. I have Symantec Personal Firewall and Systemworks. I need to know all security that needs to be...
the usb devices are diffrent u need to connect the usb cable after u install the driver it will ask u to connect the usb then only u need to connect it frist u uninstall all the old drivers & do the installion
Nov 28, 2008 | Office Equipment & Supplies
Officejet G85 printer
If you previously were using a parallel connection for the G85 you will need a USB cable.
If your laptop is running Vista the G85 will work as a printer, I do not think there is a scanner driver for Vista for the G85. The G85 print driver is built into VIsta, you only need to turn on the printer and install the USB to have the printer automatically installed.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Where is the CMOS battery?
Yes that was the cmos battery, I'll see if I can find a better solution for this issue for you.
Feb 13, 2008 | Compaq Armada M700 Notebook
HP OfficeJet G85 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
