Flicker motor on electric fireplace
The flame doesnt move so is it flicker motor or flicker rod
protek480
  • 1714 Answers
SOURCE: I need a new flicker motor for my heat surge
If you have the old motor in your hands, go to www.grainger.com and they can cross ref. with the name plate data on it, and replace it for you.
Posted on Jul 08, 2009
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 6 Answers
SOURCE: pyromaster electric fire place motor for flickering flame
Test the motor first with a 9V battery. If the motor turns it's most likely a defective Flame Speed Control circuit board PN 10001589.
Contact Southwest Fireplace
11921 S 80th Ave
Palos Park, IL 60464
708-448-3883
  • 3 Answers
SOURCE: Charmglow electric fireplace flame does not
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Posted on Dec 28, 2009
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I replace or repair the flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
Flame has stopped flickering on our Century Heating electric fireplace, model HEF26. Fuses or motor?
Probably, neither. If there's no brightness at all, the bulbs are burned out and need to be replaced. If the brightness is there, but no flickering, then it's probably the motor or the shaft that the bulbs are on is stuck and can't rotate. Really not an uncommon problem with electric fireplaces, no matter who the manufacturer is. If you don't hear a humming noise when the flame function is turned ON. the motor may have overheated and shut down.
To test this, turn the Master ON/OFF Switch to OFF and unplug the fireplace from the wall outlet. Wait 12 - 15 minutes. Plug the unit back in and Turn the Master ON/OFF Switch to ON. Turn just the flame function ON. If it starts right up, the motor has cooled and the unit reset itself. If this continues to occur on a regular basis, contact the manufacturer's Technical Service Dept. If nothing happened after it was turned back ON, contact the manufacturer for replacement parts.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flame doesn't flicker
The "flicker" function in my unit operates with a system of rotating, reflective fins. The tiny, AC synchronous motor driving the fins failed and I got one one-line for cheap. A fairly simple R&R.
Only downside is the motor does not always start in the proper direction, but a start/stop or two resolves the issue.
Apr 08, 2017 | Kitchen Appliances - Others
Heating & Cooling Logo
736 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
