Question about Garden
Need to know the make and model of this weed eater. I bought it as is but can't get the fuel tank or rubber strap that holds the tank in place without knowing, any help will be appreciated.
  • Garden Master
  • 15,956 Answers
  • 2 more comments
  • Jeff sautelet Dec 08, 2012
    Still need the model if it is homelite as the only number I can find is a number steel stamped on the motor. The number is 225474238.
  • Jeff sautelet Dec 10, 2012
    Solution did not help, I still need the model number.
  • Brad Brown Dec 11, 2012
    That number that you posted is either a serial number or a cast number for the engine.
    None of which are searchable. The only thing left would be to locate a dealer or repair place and see what they can find or see if you can come up with any other numbers that might be on anything on that machine then we can see what possible model numbers are listed to that part.
5 Suggested Answers
wadembly
  • 475 Answers
SOURCE: the rubber tube that picks up the fuel came off
it can be fixxed it should be bolted on by maybe 3 bolts or screws once you get it off tilt tank let piece fall out of the tank then what ya do is feed the new line through the top get a long pair of needle nose pliers pull line out of cap end put you fuel filter on end pull back out of top the where the filter is on bottom of tank recomect everything & its should work well for ya
Posted on Nov 13, 2009
2strokeguy
  • 183 Answers
SOURCE: I am looking for a
You did not list which model Ryobi you have, however...
If your Ryobi has a silver or black shaft, then it is an older model and requires a 32:1 fuel mix. In the USA, that is 4 ounces of 2 cycle mix per gallon of gasoline. If your Ryobi has a yellow shaft, then it was made by HCP and uses a 50:1 mix or 2.6 ounces of 2 cycle mix per gallon.
Posted on Sep 23, 2010
  • 13 Answers
SOURCE: need to know what kind
Stihl ultra is the ONLY oil you want to use in stihl or any equiptment for that matter, it will lengthen the life of your machine and save you a bundle witih the length the whole piece of equiptment will last
Posted on May 20, 2011
  • 122 Answers
SOURCE: FEATHERLIGHT weed eater model #SST25C
Pick one of the models from this link, they all use the same fuel line: http://www.ereplacementparts.com/search_result.php?search_type=1&q=sst25&manufacturer=Weed+Eater
Also if you need a descriptive video,there are some good ones under 'weedeater fuel line' on youtube.
Posted on Sep 16, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed Eater GTI 19T
    If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
    Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
    Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
    change the fuel lines over on the carby
    you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
    Mar 12, 2017 | Garden
    FEATHERLIGHT weed eater model #SST25C I need fuel and connecting plugs for gas tank? Also a schematic of this repair would be helpful.
    Sep 16, 2011 | Garden
    ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
    Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
    Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
    Replacing fuel lines on ryobi weed eater,need
    This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
    If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
    Jul 10, 2010 | Craftsman Garden
    How do you fix a broken gas line to gas tank that was previously glued but does not hold and leaks gas to a Poulan GE21 weedeater?
    Buy a new gas tank! Are you serious! Or buy a new weed eater, if you can't live without this one, those models are cheap, don't waste your time.
    Apr 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
    Need to know how to attach vac bag
    The bag should fasten to the blower where the blowing tube comes out. (blowing tube is removed to install the bag, and a pick up tube is installed on the 'screen door') It should have a tightening strap or velcro to hold it in place.
    Nov 09, 2009 | RTO Weed Eater Electric Barracuda 2595...
    Fuel hoses routed wrong on weed eater fuel tank
    http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
    Apr 04, 2009 | Garden
    Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
    Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
    Garden Logo
    32 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
