Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos quiet series 300 dryer - Maytag Bravos 7.0 Cu. Ft. Electric Dryer
  • 67 Answers
SOURCE: Maytag Bravos dryer tearing the "felt ring" on front of drum.
Mostly likely the cause was the skid pads came off or were missed aligned. You could have also jarred the drum but it doesnt matter because you want it fixed. So take off the front of the dryer after calling your local maytag dealer and making sure they have the felt, skid pads, belt, and rear rollers (just in case you find more problems).
Once you have this apart make sure you clean it good, take out the lint catcher and vacume all of the lint. No reason to put back together a nasty dirty dryer. Make sure you check the rear felt carefully and the rollers. This is a very simple job and shouldnt take more than about an hour. Make sure you take the door off first then the front panel and you have someone to help hold your tools while you think. Have fun
Posted on Aug 15, 2009
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Posted on Sep 07, 2009
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
  • 46 Answers
SOURCE: dryer wont get hot
check thermal fuse
Posted on Jan 21, 2010
Locate the heating element on my Maytag Bravos Quiet Series 300 dryer model MEDB200VQ1 video shows located in the back but the wires plug into something in the back and mine doesn't look like that.
Go to www.repairclinic.com and enter MEDB200VQ1. With luck, you will be presented with a list of common replacement parts/assemblies and may be able to view a generic Maytag video showing disassembly.
Mar 23, 2018 | Maytag Dryers
I have a Maytag bravos 300 quiet series dryer that had a error code of F73. Lights come on without code but still doesn't start. Problem?
The F73 error code means that one or more of the control buttons on the touch pad is defective. You can clear the error code by the pushing clear/cancel button, if it doesn't reoccur all is well. If it ever happens again, you will need to replace the touch pad
Apr 05, 2017 | Maytag Dryers
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
My bravos quiet series 300 will not turn on. what could be wrong
Check for power first must have all the juice one side of electric can be down. check door switch or replace Dryer electronic control board Part #: W10222206
Feb 20, 2015 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Maytag Bravo gas dryer gets too hot.
Most likely needs a new thermostat. Go online to find instructions on replacement. Make sure it is unplugged. I don't think it is too difficult to do yourself.
Sep 13, 2014 | Maytag Dryers
2 year old Maytag Bravos quiet series 300 is not blowing air out of the exhaust port.
Oh brother. These dryers have 2 belts. The small belt that drives the pulley is probably off the motor. The pulley tends to come loose and fall off. The manufacturer recommends lock-tite on the nut that holds that pulley. REPAIR PHOTO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 05, 2012 | Maytag Dryers
How do you remove a bravos heating element
Take the rear cover off and the heater is a shorty mounted on the right hand side. See page 61
Aug 08, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
887 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
