Question about Hotpoint Dishwashers
Clean the filter on a Hot point Americana model ADW1100N10WW dishwasher
Model ADW1100N10WW I need to find out how to get to the filter. The housing inside beneath the washing wand comes off but we cant get it out. We took out one screw on the washing wand housing do we just pry it up?
  • 351 Answers
SOURCE: Problem with Miel dishwasher: no water
if the valve is humming and the tap is on it should fill.is there a plv fitted to the tap somtimes they fail.i had one today on an asko for not filling.remove the hose from the dishwasher and turn the hose on into a bucket to see if water comes through.the valve could still be faulty.hope this helps.
Posted on Mar 20, 2008
Kgt1962
  • 59 Answers
SOURCE: dishwasher that leaves dishes dirty
Your drain could be blocked, remove the drain from the trap below the sink and try running the unit on drain, into a bucket. Also check the connection at the trap to ensure it is free from blockage
Posted on Mar 19, 2009
SOURCE: Roper Dishwasher Model RUD3000KQ1 is not washing clean
Ther is a small tab area on left side of screen. Lift here and work way around screen. Right side will unsnap out of drain. Snaps back in when ready.
Posted on May 09, 2009
localwonder
  • 6784 Answers
SOURCE: My Bosch Dishwasher doesn't clean
Check the following to address this issue--
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Jun 03, 2009
SOURCE: Jenn-Air Dishwasher Handle Loose
This worked perfectly for me. Follow the link that shows you which two screws to take out. It is one screw on each side of the inside door frame. One on the left and one on the right (not the top one, but the second one down). Then pull the door handle upward about 2 inches and the whole washer face comes up. Jiggle it off and tighten the handle. Only tricky thing is that you need a star screwdriver.
The problem I had in the beginning was that I took off the middle screws on top (cause that's what it looks like in the picture), but it's actually the side screws. Don't take them all off - just the two you need.
- Pokey
Posted on Nov 03, 2009
How does water actually get into the tub of a GE Model GSD2200G00WW dishwasher and to clean the overflow area how do you get it out I have cover off, down to rubber, got some stuff out, ? filter
First--Water enters the dishwasher through the water inlet valve which is the plastic electric valve that the house plumbing attaches to. On GE's its usually under the left front corner once you remove the small access panel. Power is applied by the the timer during the fill cycle. Second-- there is no other filter down in the area you are trying to clean. To remove that rubber boot/sump area you would need to un-install the dishwasher and remove the motor pump assembly from underneath. Here are a couple of things to check for poor cleaning. 1---internal water level---should be about 1/2 inch at door front edge. If not, that inlet valve may be partially blocked and need replaced. 2---water temp needs to be at least 120 minimum. If not hot enough it will not dissolve soap. 3--- look closely at all the little holes in the spray arms. Pay close attention to the end holes that are used to spray out water like a jet engine and spin the arms. Any blocked holes need to be cleaned with something like a toothpick. 4--- check dishwasher at cycle end. If tub has excessive amount of water left inside you may have a blocked drain hose from dishwasher to house drain system. Remove and clean. A small amount of water in sump area is normal but none u near door.
May 02, 2015 | GE Dishwashers
Need a water intake valve for my Hotpoint Dishwasher
I've used two web sites searspartsdirect.com and repair clinic.com
both have diagrams and probably can have them at your house within days! The first one probably has more diagrams. Good luck
Feb 16, 2014 | Hotpoint Dishwashers
My hot point dishwasher isnt cleaning very well. what can i do to help it
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Hotpoint Dishwashers
I have a KA dishwasher model number KUDM24....is there any maintenance, i.e.e filter to clean. Dishes do not seem to be getting as clean as they once were. Residual on glass ware, not bad but not...
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
On some models in kitchen aid you must lift off the spray arm and then lift the filter up. It is fastened with spring clips. On other models removing the spray arm reveals screws at the top of the filter housing that need to be removed to get the filter up.
Oct 29, 2010 | KitchenAid Dishwashers
WHY DON'T DISHES DRY? MODEL ADW1100N10WW
water tempt too low . use longer cycles like pot & pans . if d/w has a heater turn it on . always run tap at sink till water is hot then start dw . this is a common problem it's probably not the dishwasher . but how ou are setting the cycles .. mm hope this helps . feed back pls ..
Dec 22, 2009 | Dishwashers
Does not clean
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 08, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
FOOD PARTICLES ON DISHES
Hi
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Dishwasher suddenly doesn't clean well-doesn't empty soap disp
Hi
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | Maytag MDB5100A Dishwasher
Hot water for dishwasher
Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
Oct 06, 2008 | Dishwashers
Dishwasher won't drain. soap tablets melt(?) in the holder
The simplest solution to your problem is to check that the dishwasher drain system ( filter, pump hoses and house drain ) are all in working order..Check the following:
1. drain filter- clean as necessary
2. drain hose - check for kinks or restrictions in line
3. house drain system- make sure your house drain system is not limiting the flow of water from the dishwasher..
Then..
I suggest you clean anything that may be trapped in your drain filter ( normally found near the bottom of your dishwasher at the lowest point) of any debris,.. Then try cleaning the detergent dispenser with white vinegar and wipe out any and all soap or food byproduct that may have built up in that area.. Then.. start a wash ( without dishes) on the hottest setting and after about 10 minutes.. add in 2 cups of white vinegar and let it finish.. All of this should be done without any dishes in the system to clean thngs up..
If after all this you still have a pumping problem, you may have a defective pump or it has some foreign material in it that will need to cleaned out. lastly, it would help if you provided a specific brand and model so that the solution can be tailored to your appliance.. Hope this helps..
Sep 21, 2008 | Dishwashers
Dishwashers Logo
423 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
