Question about Sewing Machines
I have an old Viking Eaton sewing machine that isnt working corectly.
Last week I set up my machine and it worked fine, I didnt change anything but now it wont work. When I go to sew with it the top thread doesnt sew it just unthreads itself from the needle. I retreaded the whole machine and it still wont work at all. I even ajusted the tensions on the bobbin and machine, with no change.
SOURCE: not sewing - jamming
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Posted on Feb 15, 2009
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
sew dutch
  • 24 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
  • 980 Answers
SOURCE: my singer sewing machine no. 127 vibrating shuttle
There are no adjustments at all on that model, it has to be down to the needle for some reason
Posted on Nov 02, 2009
Can a dressmaker sewing machine, ca. 1975, sew a consistent 1/4" seam? My new Viking Saphire and old Kenmore do an awful job so I'm trying to find a better machine for quilt making.
professional machines are only better at sewing thicker fabrics-faster theyowever have difficulties doing fine work (there not made for that) I like the old Viking machines , and you cant discount the old sears machines as well , in fact unless there is an obvious flaw with them (bent parts), I cant see why they cant sew straight stitches , try using one of those stick on reference line tapes to help the operator guide the fabric straighter into the machine
Oct 05, 2016 | Kenmore Sewing Machines
My two week old machine is today making a groaning noise as it starts sewing, which it didnt yesterday. Any ideas, please?
take a look in belts and gears where the noise comes
if broquen changed and put some wd40
Sep 15, 2015 | Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
Vista cannot locate the drivers for my Viking reader/writer; although it worked fine two weeks ago.
There is a vista update on the Husqvarna site, which can be downloaded.
Dec 08, 2009 | Husqvarna Viking 1
I was trying to change the stitch setting on my husqvarna 400 sewing machine, and it seems like the panel does not respond to anything that i touch. the machine does not even go into reverse. Is the...
It could be the touch panel or the main board. The touch panel ribbon connector could be loose but not likely. Needs to be diagnosed by a good tech. for Viking.
Jul 18, 2009 | Husqvarna Viking 1
I have the Viking Emerald 118 model, less than a month old. I cannot get the button for setting whether the needle stops up or down to work. It worked fine the last time I used my machine. I also am having...
The large wheel on the side of the machine that pulls out to thread a bobbin is probably pulled out. Push it in and the rest of the features should work.
Jul 15, 2009 | Sewing Machines
Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
Jul 05, 2009 | Sewing Machines
Needle doesn't move the problem isn't the foot pedal
I have a Husqvarna #1 that I also love. My needle stopped moving too. I was convinced it was the foot peddle but a repair person sais it was not. I discovered on my own that indeed it is the cord on the foot peddle. I suspect it has a loose wire because when I wiggle it where it connects to the machine it starts working again. Right now this is what I have to do because I can't find a replacement peddle. Can anybody help me find one?
Jul 06, 2008 | Husqvarna Viking 1
Needle won't change position
MMMM got me foxed, will look into it and see if I can come up with a solution.........watch this space. Only comment I can make is computer controlled machines can be a nightmare, old mechanicals are easier to fix and cheaper.
Jan 29, 2008 | Husqvarna Viking 1
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
