Question about AOC V22 22" Monitor
My AOC V22 22 inch monitor does not work with Windows 8 Pro. Message: Input not support.
    Top Expert:
  • AOC Master
  • 36,343 Answers
You probably need an updated driver compatible with Windows 8
Posted on Dec 07, 2012
the terrier
  • 94 Answers
SOURCE: monitor
hi auntie
while the monitor is OFF press and hold the MENU key,switch ON the monitor while still holding the MENU key and voila it is unlocked
Hope this fixes you
Posted on Oct 27, 2008
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
  • 57 Answers
SOURCE: I have a Dell Dimension 3000 Tower that was hooked
fomatt it and then reload it with another monitor
Posted on Oct 16, 2009
  • 107 Answers
SOURCE: I am getting a INPUT NOT SUPPORT message for my
The resolution selected in normal mode is not supported by your monitor.
Instead of booting into safe mode, boot into VGA mode - this should allow you to change the resolution - change it to one that works and then you should be able to use normal mode.
Hope this helps, Sherwin
Posted on Dec 21, 2009
budmrtn
  • 11361 Answers
SOURCE: My AOC monitor went black and has this error
The video resolution of your PC is too high for the monitor to display.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 01, 2010
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Chris
Jul 08, 2011 | Computers & Internet
I have an AOC 22+ it is just a little over a year old (just out of warrantee) When you turn on the monitor and boot the computer the monitor will go thru its start up showing the AOC logo then it goes...
unfortunatly i believe the monitor may be dead. also check the connection on the monitor itself (the cable) some of these monitors are picky about which port is active dvi or vga there should be an option to change the input on the monitor itself from vga to dvi for the connection i hope that helps let me know!
Mar 14, 2011 | AOC V22 22" Monitor
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
I am getting a INPUT NOT SUPPORT message for my 917sw AOC lcd monitor. It does work on safe mode I am using windows vista, but when I come back to normal mode, I see the same message again... HELP!!!
Dec 21, 2009 | AOC 917Sw 19" LCD Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
Aoc 22 inch monitor gos off when live tv or movies. message comes on ,said no single. can still hear program. lee g.
monitor was still under warinty. i took it back to staples store and they gave me a new one.
Nov 23, 2009 | AOC Computers & Internet
Input not supported
1. Restart the computer.
2. When the computer begins to reboot, press the F8 key repeatedly in one second intervals until the "Windows Advanced Options" appears.
3. Select "Enable VGA Mode" and press ENTER.
4. Select your operating system from the list and press ENTER
5. Follow your normal log on procedure.
6. RIGHT CLICK with mouse anywhere on your desktop.
7. Select PROPERTIES.
8. Select SETTINGS then select ADVANCED.
9. Select ADAPTER then select LIST ALL MODES.
10. Refer to your monitor user's manual or Quick Start Guide for the recommended resolution or mode for your monitor.
11. Select OK then APPLY then OK.
12. Depending on your computer setting, you may need to re-start the computer for the changes above to take effect.
Hope its useful!
Jun 30, 2008 | AOC 193P+ 19" Monitor
AOC V22 22" Monitor Logo
287 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
