Question about Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV
Red light flashes 10 times on my sony KDP-51ws655
mistersony
  • 320 Answers
SOURCE: model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
Posted on Oct 26, 2008
  • 11 Answers
SOURCE: sony kdp-57ws550. Turn on tv = no picture, have
You have to count how many times it blinks. It is a service code. The main thing that goes on these is the convergence chips. If you had the back off doing any type of repair, recheck your plugs. Odds are, you crossed one.
Posted on Dec 12, 2009
  • 3 Answers
SOURCE: Sony KDP-51WS6755 not turning on, power surge, pop, 6 blinks.
unplug it immediately. never tolerate a sizzle (frying noise) or a popping noise. do NOT replug. fire hazard.
contact serviceman for repairs. Sears Home Service can handle this for you.
Posted on Apr 14, 2010
  • 129 Answers
SOURCE: TV will not come on, LED light flashes 10 times,
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Posted on Jul 28, 2010
  • 2336 Answers
SOURCE: Where the g board located
Posted on Sep 14, 2010
It will turn on somedays and work great other days nothing red light blinks 10 times
Thats a HV issue which is indicating that there is most likely an issue with the any of the following items all located on the D board. They are:
Transistors Q8013 & Q8014
Resistor R8051
Integrated Circuit IC8005
Aug 31, 2011 | Sony Grand WEGA KDP-51WS655 51" Rear...
Where the g board located on sony kdp-51ws655?
Sep 14, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Apr 14, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Part number for mirror in Sony KDP-51WS655
Sony Part Number: 2-023-094-01 I WENT TO A WEB SIGHT CALLED WWW.PARTSTORE.COM U MAY WANT TO GO THERE AND MAKE SURE ITS WHAT YOUR LOOKING FOR IT SAID A MIRROR (51)
Mar 07, 2009 | Sony Grand WEGA KDP-51WS655 51" Rear...
Model KDP-51WS655 - blinks 9 times
DISPLAY
5
VOL -
POWER
Oct 26, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony KDP-51WS655
how many times does the light blink?
Feb 19, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
My sony wega 51" rear proyection no turn on
Hello had the same prob need to replace DIODES, D6116 and D6301 very cheap to buy on line and then they need to be sotteried on (sp) .
Oct 15, 2007 | Sony Grand WEGA KDP-51WS655 51" Rear...
Audio no video
You have whats called a zero crossing detector problem my friend. Usually the problem is D6116 and or D6301 0n the G board.
Jun 09, 2007 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
