My speakers are not pushing out they are sucking in.
  • 29 Answers
YOUR SPEAKERS ARE HOOKED UP IN REVERSE PHASE. CHECK YOUR SPEAKER WIRE AT BOTH ENDS. POSITVE WIRE TO POSITIVE WIRE AND NEGATIVE WIRE TO NEGATIVE WIRE.
30 YR SERVICER APGONZO
Posted on Jan 12, 2009
Why won't our Bissell product below suck up the water on the carpet, but it will suck up the water on a hard wood floor?
Bissell is getting old?
You might need heavy duty wand that pushes tight into carpet.
The bissell does not push down hard enough against carpet and probably doesn't have enough power?
Gene
Oct 02, 2014 | Bissell PROHeat 2X Multi-surface Turbo...
What do the phase and cut off controls do,manual does not explain much.
Phase reverses the polarity of the driver so it can be matched to the other speakers and bass-reinforcement characteristics of its position in the room. You don't want the sub 'sucking in' while other speakers are 'pushing out' or a bass cancellation will occur.
Set it, listen to bass from your normal seating position, reverse it and observe if the bass gets subjectively better. Leave it in the 'better' position.
Cutoff is a variable for the highest frequency where the speaker 'cuts off'. You can experiment with adjusting it for what sounds to you like the smoothest transition betwen the sub and the othere speakers. You don't want a lot of audible overlap where the sub and other speakers are acting on the same frequencies. It may sound to bassy in that area.
Dec 26, 2010 | Jamo SUB 200 Subwoofer
Dont know how should the wires be wired on the sub
You have polarity problems there. Try swapping the wires and see if the cones goes up or down... You got the right polarity if the speaker produces sounds when you connect it to your subs.
^_^
Jun 07, 2010 | Kicker 01C8VR4 Car Subwoofer
When I power on my speakers, they mnitor goes
Try putting monitor and the speakers on separate power point/wall sockets as your speakers may be powerful ones sucking in all the power from the same socket as the monitor.
Nov 17, 2009 | HP JBL Platinum Computer Speakers
I think my subwoofers broken
the coils in the speaker are more than likely shot
Jun 17, 2009 | Sony XS-L121P5 Car Subwoofer
Like to keep this
Spkrs will sometimes be intermittent if the installer has twisted the frame a little or tighten down too much.Remove the spkr and see how it works when it is not mounted.If it still is not work right,then it is probly defective.Good luck and please rate this answer,thanks.
Apr 04, 2009 | Volfenhag ZX-4712 Car Subwoofer
Speaker would push out and stay out with a hum when turned on.
Sounds like the "servo" on this unit has gone bad.
You will need to contact Velodyne for service on this.
It is the only place to get parts and service for this unit.
Apr 01, 2009 | Velodyne SPL-1000 Subwoofer
Remove inside door panel without breaking it
they have push in clips that hold the panel on the door you can pull it off with your hand or go to parts store and buy a door panel removal tool
PLS take time to rate this solution and by the way you will probably need to buy new push in clips to hold panel on
Feb 17, 2009 | 1999 Chevrolet Silverado 1500
My 17 month old daughter pushed in the mid and tweeter on my home stereo is there a way i can fix it without getting new speakers a trick of the trade if you will ???
Hi - As a last resort you can try sucking the cones out with a vacuum cleaner. Choose a "low" setting (usually there is a hole you can uncover in the hose" and go carefully!
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 10, 2008 | Audio Players & Recorders
LCW-0120 Labtec speaker polarity
I am assuming that you already know which wires go to which speaker and all you need to know is which one is negative and which one is positive. Here is one way to find out. If you can access the speakers at all or at least see the cones, it will be easy.
Take a small 1.5v battery and connect it to the wires in question, connect one end to the positive(+) and the other to the negative (-) side of the battery, don't do it for a long time, just enough to observe movement on the speaker cones. Observe the cones of the speakers, if the cones get pushed or moves out, take note of the polarity of the battery because now you know which is which. Now if the cones, move inward or it gets sucked in when you apply voltage, then it's backwards.
Feb 11, 2008 | Audio Players & Recorders
42 people viewed this question
 Grubhead
Grubhead
